Reload this Page >
Air retracts - rebuild, o-rings, leaks, and sourcing parts
Old 10-24-2017, 10:32 AM
sfaust
sfaust's Avatar
Default Air retracts - rebuild, o-rings, leaks, and sourcing parts
I have a leak in one of my Airworld L-39 1:5 landing gear (left wing). The leak only occurs when the gear is up, and is leaking from the seal around the actuating arm/shaft. See photo below
I replaced the o-rings for the piston and housing as shown in the photo, but itís not clear that I can replace the seal for the shaft/arm. I canít tell if its an o-ring, or some other type of seal, and if I can get a replacement part for it. Also not sure how to disable the shaft and piston to get at the seal.
Has anyone replaced this seal? Know the procedure? And if I can source the parts?
The leak is significant enough that the pressure only holds for one or two cycles of the landing gear, and just long enough for a flight. Iím not comfortable with this for obvious reasons
Thats for the help in advance
Old 10-24-2017, 12:39 PM
ravill
ravill's Avatar
If you don't see e-clips on the piston, I would venture to guess that the piston screws on. As you know, there are obvious inherent dangers when removing that.
Of the rare times I've had to disassemble cylinders, there is usually a small o-ring that goes inside the cylinder end. Sharpened tooth pics and LOTS of patience. A good place is the O-ring store. The O-Ring Store LLC, We make getting O-Rings easy!
Good luck!
Old 10-24-2017, 12:59 PM
wfield0455
My Feedback: (7)
wfield0455's Avatar
From the photo it appears that there is at lest on hole (indent not a through hole) in the face that would indicate to me that plate screws in and the holes are there to insert the pins of a spanner into. I made such a spanner to remove the ends of the cylinders of my Skymaster small Hawk retracts. Once I got it started it screwed out pretty easily.
Old 10-24-2017, 02:29 PM
sfaust
sfaust's Avatar
If its the hole I think you are looking at, very prominent in the photo, that is the air pressure inlet for pushing the piston up and retracting the gear. But it could be used for both, assembly and for air inlet.
I'll have to get a magnifying glass and really examine the seal and see what's what. If I can't resolve it, even though it works perfectly, it's junk if it can't hold pressure for a full flight.
In the gear down configuration, the air system only lost about 3 psi over a couple hours when pressurized to 80psi. In the gear up, well, from 80psi to 0 in about 15 minutes.
Old 10-24-2017, 05:51 PM
sfaust
sfaust's Avatar
I checked the seal in more detail. It doesn't look like an o-ring, or even removable. Not sure if its serviceable. I sent an e-mail to Airworld, lets see if I get any response. Hopefully, I won't have to find a used left main gear, or have to replace the gear entirely.
Old 10-25-2017, 11:03 AM
jetflyr
Looking at the picture, it looks a lot like a Behotec unit. Simple and easy answers would be from Peter at Altecare-RC.com since he is just a tiny bit north from you. Ultimate Jets in Houston is also a dealer, so another good source.
Hope this helps!
Greg
Old 10-25-2017, 03:39 PM
sfaust
sfaust's Avatar
Hope this helps!
Greg
Thanks Greg, I'll give them a shout.
Old 01-03-2018, 03:18 PM
stegl
Default Locate air leakes
If. not already mentioned , the best way to locate leaks, is to use a mixture of dish soap in water brushed on ( or any other application) all the couplings or connections . Small bubbles will appear pretty quickly . Saves unnecessary disassembly to check O rings and seals as that might create further issues. (If it ainít broke ; donít need fixín) Once the point of a leak is found, just disassemble that part for further inspection.
Old 01-06-2018, 02:13 AM
David Gladwin
David Gladwin's Avatar
I had similar problems of leaks developing on the retract units on my AirWorld Hawks , some years ago. I believe the units are the same as mentioned here.These models are now over 10 years old and fly with complete reliability. I traced the problem to corrosion on the shafts in the area of the small seal, which seemed to hold moisture.
I replaced the corroded shafts and installed new seals with plenty of BVM silicone grease.
I also now now use a water trap on my compressor, since when I have had zero problems and the system holds pressure indefinitely.
Might help you.
David G.
Old 01-06-2018, 09:06 AM
sfaust
sfaust's Avatar
Originally Posted by stegl View Post
If. not already mentioned , the best way to locate leaks, is to use a mixture of dish soap...
Thanks. That was how I initially found the leak. Definitely in the small seals on the cylinder shaft.
Might help you.
David G.
Do you know where you found the small seals for the shaft. I replaced the air cylinder seals, but haven't found a source for the small seals on the shaft. I also don't know the correct procedure to remove the shaft, and don't want to make it worse or break something just trying things. Any help in disassembly of the shaft and source for the small seals would be so much help and save me buying new gear as a solution.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
