Maj. Woody's Skymaster 1/5 F-86 >
Old 12-11-2018, 09:59 AM
  #151
ravill's Avatar
And this is why we love the Maj Woody builds! Amazing build Dom!
This is RCU gold!
Old 12-11-2018, 11:05 AM
  #152
My Feedback: (28)
MaJ. Woody's Avatar
Thanks Rav you are too kind. I can only hope my Sabre turns out as well as yours. I saw the Swat video and loved it.
Old 12-15-2018, 03:24 AM
  #153
My Feedback: (28)
MaJ. Woody's Avatar
Does anyone know if I am going to need up or down elevator trim / mix when I add flaps? If so how much and what direction?
Also, do the drop tanks change the CG at all? Just wondering if I could fly with or without them without having to worry about the CG. I will test this when I am balancing the model, but wanted to know in advance.
Thanks!
Old 12-15-2018, 06:14 PM
  #154
HvyDrvr's Avatar
Major, on mine, which is identical to yours, If the speed was in the 70 mph range (I have a GPS with voice speed) no trim needed for either flap setting. Also my slats were mixed with flaps so that when you had full flaps you also had the recommended slat extension. I did not fly with the fuel tanks installed yet but do not think they will affect to w&b much if any at all. One thing I noticed is that with full flap and gear out if you a bit hot, it is a real floater. I found that 48 to 50mph on touch down is perfect and the flare is uneventful. I'm assuming the Spektrum GPS is telling me mph rather than knots. Also I was flying with the CG at 395 mm.
Rod
Old 12-16-2018, 03:29 AM
  #155
My Feedback: (28)
MaJ. Woody's Avatar
Awesome. Thanks for the feedback Rod!
Old 12-16-2018, 12:01 PM
  #156
My Feedback: (21)
Thanks!
Dom,
It all depends on where you set neutral for the elevator. I need to add up trim for flying but needed down trim for the flaps at half and full. Just be prepared with the flight mod switch set for trim with the different flap positions.
Old 12-24-2018, 11:50 PM
  #157
Dom,
You are a true craftsman! Thanks for sharing and explaining every step with pictures.
Regarding the reinforcement of the retracts rails and using bolts with blind nuts, isn't it "too strong"? Wood bolts can be used as fuses in case of hard landing and they will be ripped off instead of causing internal structure damage.
Avi
Old 12-31-2018, 03:17 AM
  #158
My Feedback: (28)
MaJ. Woody's Avatar
This is how the door linkage comes from the factory. It worked well out of the box but when I set the toe on the wheels, it changed the geometry and the ball link pivoting kept my door from moving over where I wanted it when closing.
Old 12-31-2018, 03:23 AM
  #159
My Feedback: (28)
MaJ. Woody's Avatar
To stabilize things, I machined a standoff with a recess to capture the ball that effectively stopped the link from pivoting at one end. The door closes as it should now. You may notice that the door attachment tab looks different between the stock setup and the modified. That is because the cheap plastic tabs broke off of both doors and I had to replace them.
Old 12-31-2018, 03:24 AM
  #160
My Feedback: (28)
MaJ. Woody's Avatar
Tonight I will be putting the finishing touches on the right wing panel and both wings are complete at this point. Time to move on to the tail!
Old 12-31-2018, 03:59 AM
  #161
My Feedback: (21)
great job Dom. I made a "ramp" that was glued to to the strut with a piece of brace tubing on the threads of the rod. as the gear comes up it allows the door to be pushed into place.
Call me when you start the tail. I have pics of my set up.
Joe
Old 12-31-2018, 05:18 AM
  #162
My Feedback: (28)
MaJ. Woody's Avatar
Thanks Joe!
Old 01-01-2019, 07:52 AM
  #163
My Feedback: (60)
amazing work Dom! Thanks so much for doing this. Looking forward to watching the progression.
-S
Old 01-01-2019, 03:36 PM
  #164
My Feedback: (28)
MaJ. Woody's Avatar
-S
Thank you for reading the thread and providing the motivation!
Old 01-01-2019, 03:37 PM
  #165
My Feedback: (28)
MaJ. Woody's Avatar
The right wing panel is now complete.
Old 01-01-2019, 03:41 PM
  #166
My Feedback: (28)
MaJ. Woody's Avatar
As stated earlier, I rubbed out the wings when I finished their construction. I used Novis #2 Polish.
Old 01-01-2019, 03:45 PM
  #167
My Feedback: (28)
MaJ. Woody's Avatar
Both wings are now tucked away and I will start on the tail this weekend.
Old 01-01-2019, 04:09 PM
  #168
My Feedback: (28)
MaJ. Woody's Avatar
Originally Posted by two dogs
Just watching this again. What a great job you did flying the Sabre from that short strip. Excellent!
Old 01-01-2019, 08:37 PM
  #169
Springbok Flyer's Avatar
Cool
Yes, nice approach and landing. The Sabre Dance looks light, don't see any leading edge slats being used at all. May I venture to say the loud whistle is an airframe noice, probably because there is no full bypass installed (or am I wrong?)
Cheers,
JanR
Old 01-03-2019, 09:26 AM
  #170
My Feedback: (28)
MaJ. Woody's Avatar
Moving on to the tail, I immediately encountered a problem with the installed hinges. Just removing the elevator from the stab (the hinges come pre glued into the control surfaces only) caused on hinge to snap in half. Putting a little pulling force caused anothed failure at the pivot pin. I have no choice but to grind out all of the supplied hinge points and replace them with high quality Robart hinges. Dont be fooled or trust these imitations.
Old 01-03-2019, 01:12 PM
  #171
Very true Dom, the same goes for the airline couplers.
JanR
Old 01-03-2019, 01:28 PM
  #172
ravill's Avatar
ACK!!!
And on a “Jesus” surface no less!
Hmm, I wouldn’t trust any hinge on the airplane after that.
Old 01-03-2019, 03:34 PM
  #173
My Feedback: (44)
RCISFUN's Avatar
Dom, I think I read on here where you can take a piece of Brass tube with a slightly larger ID than the OD of the hinge, heat it up and press in to remove old hing points.
Old 01-03-2019, 03:59 PM
  #174
My Feedback: (28)
MaJ. Woody's Avatar
Wow that is an interesting idea. Thanks Rich!
Old 01-03-2019, 05:08 PM
  #175
My Feedback: (12)
Thanks ....love the SKYmaster F 86, flys great......."Sabre Dance" is neat paint scheme....
Full bypass ...whistle at 50 percent throttle...whistle stops above 60% throttle JC P180
10mm slats on take off
20mm slats landing
TwoDogs
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
