Maj. Woody's Skymaster 1/5 F-86
#201
Hi Frank!
So very nice to hear from you. I have been following your airforce as your birds pop up in a number of threads. Glad to hear you and Karen have settled in. I think you may be looking for how I did my Wing Fences on my Skymaster Hawk. Here is a link to the Build thread and the fences can be found starting on page 18. Hope to see you at an event this year!
http://www.rcuniverse.com/forum/rc-j...-5-5-a-18.html
Thank you very much for the link, it is exactly what ive been hunting for!
Perhaps we'll see ya at one up both this season.
Take care,
Franko
#202
AB, CANADA
Hi Two Dogs.
I have been chipping away at it slowly. Last with winter I built two flashes and that dominated all my time. It felt like a second job! This winter I made snowmobiling my priority since I missed so much of it last year. Since I last updated the thread, I painted the inside of the rear fuze, finished then tail, installed the elevator and rudder servos and pushrods, set the throws and am now working on the speed brakes. I have those painted and am working on the boxes. I mounted one of the mylar boxes but decided the fit and finish sucked but the real issue is the wavey cheap mylar construction. Even after lightly glassing the outside they were still flimsy and mishapen. Yesterday I started over and am scratch building them from 1/32 ply. I made balsa templates and will test fit the box before cutting the parts out of plywood. Once the boxes are done I need to figure out the scale details for them. The included vacuum formed piece is not up to standard. I wish I could get a hold of the Details 4 Scale kit but I don't think they are in business right now. At some point I will update my thread but with the summer season close at hand I think my building will be minimal and what time I do spend on the Sabre will be in the shop so I won't update the thread in real time like usual.
Dom
Dom
#206
Dom,
I hear your pain with those parts, but feel I should warn, that you do not allow yourself to add any unnecessary weight to the rear off the F-86. It is extremely difficult to Cg this jet without adding lots of nose weight and this alone can make it a very heavy model.
On another point; I trust you've checked the secure mounting of the elevator servo mount in the fuse. SM's gluing of that mount is terrible. I also suggest, that if you used the SM c/f pushrods, that you pin them to the end caps.
Just my 2c.
JanR
Just my 2c.
JanR
#208
Dom,
Just my 2c.
JanR
Just my 2c.
JanR
I checked the servo plates and they are glued well and also have carbon fiber cloth on them. I used the Dave Brown Arrow Shaft System for my pushrods. I have pictures of everything and i will update the thread at some point.
#210
Well I had serious sellors remorse so I decided to keep my Sabre. I will resume work on it this fall and update the build thread as I go. I may update the thread before that as there is a lot of work I completed that has not been documented yet. KY Jets had me very inspired as there were several Sabres there is assorted sizes.
#211
Dom! Keep the Sabre!
86’s are sweet hearts and fantastic flyers!!
Take your time, enjoy the build and please keep coming back. Your builds are EPIC and quite the contribution to our online community!
Here is is one of the 4 Sabre’s I’ve owned. All but one, as far as I know, are still alive and kicking!
#214
Avi
#217
I bought a bunch of Viton tubing is a few sizes from McMaster Carr. All my Gas planes had Tigon inside the tank and this would get stiff within a season or two. I replaced it with Viton and have not had a problem yet but its not quite been a year yet so time will tell. I am prepared to swap the lines inside my jets tanks for Vtion but so far I have not had a problem with the Tigon. The Viton is a bit more flexible esp[especially the 3/16 ID.
