Mibo A-10 Gen 6
#302
The system I’m going to try, electronically just makes smoke and I’m using the programmable unilight controller for the light.
My A-10 is also getting a sound system. I did it on my small A-10 and it was pretty cool! True, with the engines on, the sound was hard to hear, but I still liked it! Let me see if I can find the video of my A-10.
Also, I installed wingtip vortex smoke generators too!
#303
Looks like we are the same page about going far in a project Ravill
#306
Smoke-Systems
I had to buy two systems. The wingtip’s come on under a Specific G-load. Very cool system. And if it looks good coming out of the gun, then it’s going to look great!
#310
Do you mind sharing a video Ravill ?
#313
Ravill ... I did exactly the same on mine and I mean the same !
Got the Top Gun movie soundtrack and a RedFlag mission audio ...
Which module are you using ? Mine is a Model Sounds Inc. from David Harrison.
I'll try to post a video
seaside535 (05-13-2020)
#317
#319
#322
Thanks Edgar for the tip.
I will try to hook the LG to the LG box, I don't know in which polarity I should plug the battery as the gear is retracted now.
I'll try to explain my A10 story a little, we are all here to share I guess
I bought my A10 in 2016 directly from Bogo, it's a Gen 5.5 with the eletric brake ... I almost burnt the whole plane by inadvertly plug the brake unit when I was working on the plane. All the cables were burnt ...
I then took my plane to a painter. It was in October 2016. Unfortunately the painter has given up the modelism so he didn't worked on my plane that much. He has only done the 3 base colors on top of the primer applied by Bogo.
I had the same issue as Ravill with the primer, the fiber was not cleaned before priming so the paint is not sticking to the plane that great ... And my painter didn't correct the issue by removing the whole primer and cleaning the plane properly.
After 3 years, I finally got my plane back in October 2020. I thought that the painter would finish it one day but obviously I was wrong so I finally decided to get it back to the workshop and do the job myself.
But after 3 years I forgot all the config I've done
Neither the less, I'm doing the finishing, decals, weathering etc ... all alone and it's fun ! I'm learning a lot in the process and seeing the result getting better each days is awesome.
I'll try to post some pictures but the way is still long to go before finish.
#323
Hi
Mibo A10 and almost all rc composite planes and jets are not finished in primer, but in gelcoat. To properly paint these, usually, you have to take the shine out with 1000 grit sand paper or equivalent. before painting a primer as to be spayed to promote paint adesion, if you are using 1K base coat. Skip this and the paint will come off when masks applied
Regards
Nuno
