Aviation Design / Avonds F16
I have just acquired a 2nd hand F16 which was advertised as an Aviation Design F16 but now not too sure as it certainly has some Avonds F16 detailed additions..... not bothered as to which kit it is as they are both great models just want to be sure so does anyone know any differences in the models so I can definitively know which one it is.
That must have been some trainer that could midair a jet. Usually the faster plane hits the slower one. What was you spotter doing?
That's supposed to be sarcasm, if it's not obvious enough.
I suspect it's possible or even more likely that the hatch is cut after the upper fuselage is taken from the mold - but I've also never built one, so that's a wild ass guess!
My Feedback: (18)
My Avonds hatch was clearly molded in and not cutout. I'm not saying the two jets aren't both 1/6.8 scale, I just don't know how they could be from the same mold.
The Avonds is a much lighter airframe (was made for turbine or IC Ducted Fan) due to the foam and balsa sheeted flying surfaces, but the AD has all the panel lines and more detail molded into them. Both great jets, just made a little different.
Thanks for the comments guys... the fuselage does feel relatively heavy as the original owner has reinforced considerably. ..... and the scale additions look to definitely be Avonds and I will certainly add more..... I think the tailplane control could be the definitive decider so I will try to post a pic tomorrow.
My Feedback: (22)
as for jets that were the same, wasnt the spider jets F16 the same as the Avonds?
