Harlock RC Viper 140
#227
I am selling one for a friend, it is setup as an EDF currently. It is the White, Silver, Metallic Blue, and Orange Scheme. It has the Electron 30 Landing gear and brakes and has only 5 flights on it.
DS-51 EDF and Jeti mezon ESC 12S Gensace pack.
Located in Ft. Wayne, In. area
#228
Harlock RC website is back up, Black Friday specials of 10% off jets, so they are clearly in business, which is great news. They are also responding to emails again, albeit slowly.
#240
Oh....geeze it's been so long, if I were setting one up right now without a manual I'd probably max out the throws and set about 25% expo, and have a low rate of about 70 percent of full throw. Those live hinges on that thing don't have enough room to give you scary throw even if you max them out.
The CG mentioned above is spot on, that 90mm crap in the manual, i ran out of elevator trying to flare the first flight and got "doing carrier landing" cracks from the peanut gallery.
#241
My Feedback: (14)
[QUOTE=BarracudaHockey;12754329]Oh....geeze it's been so long, if I were setting one up right now without a manual I'd probably max out the throws and set about 25% expo, and have a low rate of about 70 percent of full throw. Those live hinges on that thing don't have enough room to give you scary throw even if you max them out.
The CG mentioned above is spot on, that 90mm crap in the manual, i ran out of elevator trying to flare the first flight and got "doing carrier landing" cracks from the peanut gallery.[/QUOTE
I’ll try that thanks again
#247
My Feedback: (14)
HI Andrew the article was very help full , I decided to install my K45 g4 in it so by looking at the pics you posted in the article help me with the placement of the turbine was also wondering the pipe that you install in the plane looks like 3 inch pipe for water heater exhaust that you can get at Home Depot is that what you installed or was that a custom pipe ? I have an Sebart Avanti turbine pipe that was thinking of installing instead but is a single wall don't feel to comfortable with it would rather use a double wall pipe , would like to know more about the pipe you install in your viper , thanks for the info .
