Reload this Page >
CTU Telemetry support for PowerBox CORE transmitter
Old 12-04-2018, 06:33 AM
Carsten Groen
Carsten Groen's Avatar
Thumbs up CTU Telemetry support for PowerBox CORE transmitter
Happy to announce that the CTU now has support for the new PowerBox CORE transmitter.
(More on the CTU here: http://www.rcuniverse.com/forum/rc-j...ti-%2A%2A.html)
I have a feeling that the CTU is one of the VERY first devices in the world that supports the CORE transmitter from PowerBox (https://www.powerbox-systems.com/pro...uersystem.html)
More testing and fine-tuning coming, but so far it looks really nice
I made a "not so good" video of the "first light" between CTU and CORE (using simulated/recorded data from a JetCentral engine)
More as things progresses!
Old 12-04-2018, 02:01 PM
Springbok Flyer
Springbok Flyer's Avatar
Fantastic Carsten!
Old 03-24-2019, 08:07 AM
Carsten Groen
The first release of the firmware for the CTU that supports PowerBox CORE is now available for testers, more info thru Fast & Curious and dealers.
Latest video, showing Kingtech G2 ECU.
More features coming in the following weeks
Old 03-24-2019, 01:22 PM
fireblade5437
fireblade5437's Avatar
Smile
Carsten
Will be nice for this to be available after nearly getting it for the Wea! Will this be useable with Jetmunts ie 140XBL ?
Alan
https://youtu.be/jxXkuYy7fHg
Old 03-24-2019, 09:52 PM
Carsten Groen
Originally Posted by fireblade5437 View Post
Carsten
Alan
Thanks Alan,
yes it will, I support pretty much all engines on the market
With the CTU, you have a "one solution can cure all" telemetry unit
There are also new features on its way (auto-throttle etc), more on that in the "Jeti CTU" thread linked in my first post)
Old 03-25-2019, 10:23 AM
fireblade5437
Carsten
Just read through the Jeti/CTU thread....interesting will get a unit off you once I get a Core, nice work!
Alan
Thanks Alan,
Old 03-26-2019, 12:34 AM
digitech
My Feedback: (10)
digitech's Avatar
New update available for the CTU core version
Programmer version 2.3
Firmware 0.94
added : Status display for ALL engine brands..
after flashing you MUST do a sensor rescan and apply all settings again , Don,t forget to note them before you upgrade!
Please use ONLY the latest programmer version : https://www.dropbox.com/s/717ygp9rgv...202.3.exe?dl=0
Firmware : https://www.dropbox.com/s/98buazx9vt...mware.sfw?dl=0
Old 04-03-2019, 03:21 AM
Carsten Groen
Autothrottle function running on the PowerBox CORE version of the CTU now
Doing the final checks etc, but there is light at the end of the tunnel
Old 04-03-2019, 05:56 AM
fireblade5437
Keep at it!
Just got my unit....excellent build quality
Alan
Old 04-04-2019, 10:53 PM
paulhat
Nice work Carsten.
just some feedback on the screen layout.
You have CTU on every data box. For me it’s the first thing that catches the eye when I scan for a value.
i reckon removing CTU from each box would make it a whole lot easier to read.
i guess you have done that so the user knows where individual data points are coming from?
maybe it could be an option to turn it on or off..
Paul.
Old 04-04-2019, 11:03 PM
Carsten Groen
Originally Posted by paulhat View Post
Nice work Carsten.
Paul.
Thanks Paul
The "CTU" is can't be removed from the boxes, this is taken from the protocol, the device needs to identify itself on the bus, and this name is then shown each place. You could have more sensors with the same "type of data", then you would need the name from the sensor.
Old 04-05-2019, 08:29 AM
fireblade5437
Old 01-06-2020, 04:21 AM
fireblade5437
Just a quick thank you to Digitech both Sandor and Carsten for their great service they have recently provided on their CTU for my Core..1st class..
Alan
Old 01-06-2020, 04:26 AM
Carsten Groen
Thanks Alan,
always nice to get feedback like this
Old 01-06-2020, 05:37 AM
fireblade5437
Carsten
Your welcome 😊
Alan
Thanks Alan,
Old 01-07-2020, 04:44 PM
RC_MAN
Can you post how this was hooked up on the Core radio please
Old 01-09-2020, 05:27 AM
digitech
My Feedback: (10)
digitech's Avatar
connect the RX outpuit thru a Vcable between the powerbox telemetric and the receiver.
use the special setup software to program the ctu.
connect turbine ecu and done.
Old 01-09-2020, 01:34 PM
dribar
In the manual it says "Connect the CTU RX output to your Receivers input". What input are we talking about? I have a PB Mercury and 2x 26D receivers.
Old 01-13-2020, 10:24 AM
digitech
My Feedback: (10)
digitech's Avatar
you use a Y-lead and put the CTU between yopur mercury and the Receivers telemetric input.
Old 01-13-2020, 10:25 AM
digitech
My Feedback: (10)
digitech's Avatar
New Update CTU for Core Version 0.97
added : Multi Engine
download from our website :
https://www.digitech-aerosports.nl/product/783681/ctu
Old 03-04-2020, 10:41 AM
jimibar
I just got my Digitech CTU and I'm trying to do the setup with the Core. there is nothing in the manual regarding the Core or any powerbox unit.
I checked on the Digitech website and I saw the firmwares but which one is the one for Core ? I find only Jeti and Futaba ?
I'm sure the unit is amazing but you need to work on the documentation guys, at least for the Core part.
Any help also on the connections because i'm not sure the message above is clear enough for me.
Thanks a lot in advance !
Jimi
EDIT : I'm using a PBox Mercury with 2x 26D sat and a kingtech K160 G2 turbine.
Old 03-04-2020, 11:50 AM
digitech
My Feedback: (10)
digitech's Avatar
hi Jim
the firmware is on our page just below the Jeti.
for setting up the CTU for core you use the Programmer wich is also on our website almost at the end of the page.
no there is no manual since all connections are the same as the jeti version.
you connect the ctu to a computer , start the program and set your data there.(settings) dont forget to safe.
after that you connect your CTU between the Telemetric lead from any other unit towards the telemetric port from the powerbox receiver.
use a Y lead wich works best..
if you have any other questions let us know.
didnt the Dealer tell you this when you purchased it?
Old 06-20-2020, 02:27 PM
jimibar
Hey guys, I need to setup an alarm for Turbine flame out or whenever the turbine is shutting down.
Is it possible ? Can you tell me how to do it ?
CTU is connected to a Powerbox Mercury and my Core is at the latest firmware version.
I tried various way but can't figure out how to do it ...
Thanks !
Old 07-21-2021, 04:42 PM
GoldenEagle1
OK, I've flashed the .sfw file and connected the CTU to the Core RX fastrack/data port. Seems to have loaded as manual states. Connected CTU to GSU port on Kingtech ECU - no ecu light on CTU. Connected CTU to RXAux port on ECU and still no light. Some other connection to ECU? I really love guessing when installing electronics! Previous reply says I need a y-connector to both RX and Powerbox... where in the manual does it say this? Also says I need to download Programmer and set up unit.. tried this and it doesn't respond to the connected CTU. Again where in the manual does it state this... where are instructions for Programmer? If and when the CTU is connected properly, how do I find the CTU screen on the Core TX? Searching various forums is not getting me anywhere. Where's the support for this product? These last posts are over a year old ... why no definitive response?
I bought the CTU because it appeared to be an attractive product. The manufacturer's lack of interest in providing clear, concise instructions for connections and setup with PB Core is extremely frustrating and has wasted many hours of my valuable time. If you are going to promote a product as being compatible with Core, do the damn work to assist your customers in making it operational! Vague remarks that don't address the issues using Powerbox nomenclature but instead saying "it's just like Jeti" doesn't cut it. Likewise, to continue to rely on an outdated manual is the height of laziness. Get your customers what they need without this drama!
Old 07-22-2021, 03:53 AM
Dansy
My Feedback: (53)
Dansy's Avatar
Works great on Jeti, not sure why it would be different on the core…..I have it in all my jets…
Not sure about the core sorry….
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
