Xicoy - LG15 Gyro Controlled Brakes
#153
Do you know if anyone has tried the Er30 Electrons in a T1 mini with the LG-15? I have a set of Er30 retracts, they seem like they might be a little small for T1 mini...
#156
My Feedback: (53)
In both I’m retaining the LG15 since I already have them, I purchased the retract with no controller..... Electron Spain send me the setting for both set.
#157
My Feedback: (46)
I have a set of er30 for my mini....and a set of er40 for my T-1.....I will install that shortly right after I’m done with my Havoc SS, which is getting closed...
thx!
#158
My Feedback: (53)
Amps nose 0.5
amps main 0.5
time 10
unload 0.06
#159
hey guys i have a gs 200 in a t1 this is the problem im having. turn steering wheel to left no problem,turn steering to right and after about 2 seconds it goes back to center without moving stick.let off stick and wheel will move again to right.only does it when stick is at full travel.i can plug steering servo directly into mercury and it does not do this.thanks
#160
Kind of weird. Must be in the GS200. I would recheck all programming settings. Then if I did not find the smoking gun, I would save the programming to the SD card, reset to the defaults and start over. If that did not work, I would contact Gaspar. He may want you to send the file or the unit to him.
#161
#163
I’m not saying that disabling the Mercury gyro will fix his problem, I’m just saying it might be worth trying to eliminate variables. I had some issues that were resolved by disabling the Mercury gyro, that’s all I’m saying.
#164
bodywerks (01-31-2020)
#166
#168
I’m using a DS-24 and I’ve got my travel set to 100% on the LGC15 and have not seen this issue, I’ll definitely watch out for now.
#169
#170
My Feedback: (53)
While I know that 80% on Jeti is 100% on most other radio system......I have been using 100% for all the gear controller, electronic valve ect.....without any problem...since you need to program all these, so they should pickup only 2 things......the low and high end points...
#171
#173
My Feedback: (25)
Ive been reading this very informative thread and purchased an LG15 for my Ultra Flash Evo.
I hooked the LG15 to the nose gear and set up RC per the LG15 instructions however the gear will not cycle.
I can hear the gear motor give a momentary click when I input a command on the radio but it does not move.
I did remove the 2 pin connector from the JP gear and install a 3 pin connector so the ground and signal
are plugged in correctly on the LG15. I tested the gear motor with a servo tester and it cycles fine.
EPA is set to the max on my Futaba 18SZ.
Any ideas?
Any ideas?
#174
You mentioned a ground and signal wire from the LGC15 to your retract, just want to make sure you meant ground and positive voltage wire, there is no signal wire coming out of the LGC15 to the retract. Also, you want to make sure that when you change from the JP two pin to the three pin that the red and black wires are in the end slots of the three pin connector, with the center pin blank. Tom
