Xicoy - LG15 Gyro Controlled Brakes
#176
#177
I'd have to dig into mine, … But if I recall correctly, the OEM's two pin connector has the contacts right next to each other. If you put the pins in a normal JR connector, don't they have to be right next to each other? (i.e. NOT with the middle slot left open.)
On another note: I was taught that before you start modifying stuff, you first make it work as configured from the OEM. Then once you have it working, say on the bench, then you can frig around with desired mods.
Also, you did not mention that you set the current limits in the LGC 15. I had to up my limits significantly from the defaults.
You also did not mention if you used a voltage regulator. What is your input voltage? If it is too low, then the gear will not drive. If it is to high you can burn out the gear motors.
#178
#180
I’m glad you got it sorted out. I did that same thing with a Powerbox Mercury a while back and instantly fried the diodes, hopefully the LGC15 is more forgiving
#182
My Feedback: (25)
Ok pulling my hair out now.
I installed everything into the jet and now the gear are not working.
I reinstalled the stock JP controller and everything works fine, so it cannot be a retract motor issue.
I relearned RC multiple times, Im in standard servo mode using futaba.
motor amps set to 1.0 amp.
Some strange things I'm noticing, I cannot cycle the gear manually using the controller.
When I monitor the radio screen and command gear up (nothing happens) however, after about 8-10 seconds the status screen switches back to gear down even though I did not command it on my radio??
I have my EPA maxed out PW shows 820ish to 2130ish.
I also notice my brakes on the radio screen momentarily indicate on, even though Im not commanding them.
Im not sure if they are turning on or not as they are not yet plugged in, Im just trying to get the gear to cycle.
Im at a loss, it worked on the bench yesterday and now nothing??
#183
#184
My Feedback: (25)
Hi Tom, thanks for your willingness to help.
UPDATE..one main gear works just fine??
I can access all screens on the controller just fine, when I push retract or extend on the screen it does not cycle the gear.
I tried changing the start up mode, its on immediate so it should retract right away.
my timeout is set to 10 seconds i changed that too with no luck.
Im at a loss. I just removed it and reinstalled the stock JP controller which works flawlessly.
I guess ill just be doing my best to land slow so I can avoid killing my tires as those JP breaks grab way too hard.
In the mean time I will contact Dirk and Gaspar and see about exchanging this unit for another one.
#186
My Feedback: (25)
I did it on the gear connector to the motor, after further reading though that is irrelevant as it it would only change the direction the gear moves when flipping
the switch. The unit powers on and I can cycle through all the pages just fine.
#187
My Feedback: (53)
What mode are you trying to set with the TX and what system your using?
Its a pretty simple process, yap reversing the motors wire have nothing to do with it......obviously if nothing is moving its not programmed....correctly or defective...
Now you say you change the timeout...so its a programable unit...humm
#188
#189
My Feedback: (64)
Question on mounting the GS200 or LG15. Does orientation of controller matter? I have seen them mounted sideways, but did not know if this would affect the operation of the steering gyro? My sense tells me that since it is only working in one axis, it does not matter.....but want to confirm before mounting. Thanks!
#190
#192
Hi guys. Who is using TX Jeti DS-24 + GS200 or LG15? What switch did you assign the brakes to? They can be assigned to one of the microswitches SO on the underside of the transmitter? ***winter***
#194
Switch labeled SO: One button has a range of -100% - 0% the other button has a range of 0% - +100%. I just want to use one of them. I don't know if it will work when the range is from 0 to +/- 100.
The SP switch works the same way. ***winter***
#196
My Feedback: (53)
The point is, I only want to use one of the two buttons. It doesn't matter if it's SO on the right or SP on the left.
#198
I prefer this setup, but it has some drawbacks as it is requires more programming to configure (although Jeti makes it easy). For example, you have to do some programming if you want a parking brake and you have to program it to disable when the gear are up.
#199
It's OK ... Sometimes it's not easy to explain your idea in a few sentences. So that the other party understands it immediately. Especially when English isn't my native language. However, these discussions are beneficial for all. One will learn a lot of things. Or when he knows the answer, he likes to share with other modelers. ***winter***
#200
I have my brakes configured such that they only operate when the gear are down. To apply proportional braking I simply move the right stick up (I use mode 2).
