T-One Models Micro T1
#151
I have one on order. Ordered it on 5/30/19.Along with it I ordered one of the Kingtech K45G3's. Should be here soon. The reason I say this is that I would like to sell it as a combo when it gets here. It is the PNP version. It is either going to be in the Audi scheme or the Blue Angels scheme. Had it changed to the Audi scheme about 3 weeks after I ordered it. Dirk wasn't sure it could happen.Reason for selling it is that I want to order a Rebel Classic. Dennis
#152
My Feedback: (7)
I’m starting to sort out what kind of receiver to use. I’m a Spektrum radio person and usually go for the PowerSafe receivers but starting to worry about the extra weight. A larger jet can easily handle the large PowerSafe and two LiFe batteries but not so sure about this micro. A smaller jet probably needs something like a 9350 but not so sure it’s able to handle all those HV servos of a PNP and the electric gear
#153
My Feedback: (53)
I have a small jets that I’m doing different models but the same size with a 45..I’m going to use a rx12ch since we need at least 11 ch’s with a dual RX battery....Pretty sure a 2x 850mAh would work just fine and a 1100 liFe for the ECU, it’s also an all HV setup with electron r30 gear.
I don’t think I would fly jet now days with a single RX battery.....if on the bench if the 2x 850 don’t seem to last long enough....I can always bump that up....or if ballast is required they will be bump instead of lead....
#154
Every Jet <2M that I’ve built in the past 3 years has been set up on a single rx pack. In 1/2 of these, that pack also supplies the ECU power. All of these jets have typically been flown multiplied times a week and all have been reliable. Look back a bit in this thread. The T-One Micro I built for David has (1) 2s 4000 LiPo that runs the entire airplane. Today’s batteries are vastly more reliable. Today’s radio systems provide constant status of the packs condition. I know most will be uncomfortable with this setup but it works very well for us
Danny
Danny
#155
My Feedback: (53)
I run KingTech so they need a 3S Life of a 9-9.9v so 2s is out and there’s nothing out there to provide a good voltage regulator, that I know off....you think you save weight ? For sure you are saving space....maybe not??
#156
https://www.aeropanda.com/products/j...8ed27cd0&_ss=r
Been using these for years in all types of aircraft.
Danny
#157
My Feedback: (53)
Danny
#158
Danny
#159
This is the power wiring for David’s T-One Micro. Since it’ uses an X45 there is no need for the SBEC since the X45 runs off a 2s pack. If using a Kingtech I’d insert a SBEC before the receiver.
Danny
Danny
WI53072 (03-21-2022)
#165
So almost 16 weeks for a non plug and play I guess. I have a Mini on order since beginning of July and was told about 12 weeks. Flying season is coming to an end here anyway. Just hope I get a notification as Dirk told me when I spoke to him before I ordered that they let you know it's ready before they ship so you can coordinate with them when to ship in case you'll be out of town. Some guys in the Mini thread posted that the plane just showed up at their doorstep without even a shipped email notification.
#166
My Feedback: (7)
Well, i received mine today. Looks to be all intact. It was packed in bubble wrap, tons of foam and then a honeycomb type of heavy duty cardboard and strapping. No damage that I can see. Didn’t receive any notice from shipping company. Just my local postman knocked on the door and handed it to me.
#170
#173
