Powerbox Core radio and set up thread. >
Old 02-09-2020, 04:23 AM
  #351
If it says nothing to install are you sure they are not already there?
Old 02-09-2020, 05:56 AM
  #352
Maybe?, right now it defaults to a creepy man's voice can't find the option to change it, looking for something a little more pleasing for the ears
Angus
Old 02-09-2020, 06:04 AM
  #353
Got it, hold the play arrow for a few seconds.
thanks for the reply Dave, as mentioned amazing radio lacks a tad on instructions, thank goodness for these forums
Angus
Old 02-09-2020, 06:38 AM
  #354
Angus
Its takes a few seconds to update itself also, I get people stabbing the screen because something hasn’t come up instantly, you learn to pause!
Holding the button is one of the features to get used too, not having the Tx too close to the Rx when doing any changes/updates. Waiting for the Tx to fully boot up before switching on the model are all important steps.
Manual will develop, but I have never read any of the examples, you learn the process and I can get most things working using logic!
Enjoy, it’s an amazing bit of kit...we just need to learn the new ‘normal’
Dave
Old 02-15-2020, 08:19 AM
  #355
Maybe a silly question, but as I am lazy and have not been able to read the full thread yet, why is the update so "slow"? Is it a hardware issue or is it something that will be able to sort out later through software/firmware updates?
Old 02-15-2020, 11:28 AM
  #356
Transmitting the changes? It’s like updating your computer, iPad or phone, it is never instant.
Old 02-15-2020, 02:49 PM
  #357
I guess it depends what you're used to. I've just updated my Core tx and both rxs' in a carf Viper and it took me about 2 or 3 minutes. Being able to update rxs' from the Tx saves a massive amount of time. With any other system I've owned, I had to gain access to the rxs which are usually buried somewhere in fus, find a binding plug etc etc.
I guess it's all about what we're used to but for me the Core system taken as a whole across all the updating we have to do it's super fast.
Bob
Old 02-19-2020, 02:54 AM
  #358
Am I the only one to have issue with the touchscreen ? It does not react quickly and sometimes I need to push several time on the on screen button. We are really far from the reactivity of our mobile phones for example.
Is it a normal behavior ?
Old 02-19-2020, 03:00 AM
  #359
David Gladwin's Avatar
Default Corr
Have you removed the screen protector !
Old 02-19-2020, 03:25 AM
  #360
Yes
Old 02-19-2020, 04:24 AM
  #361
I have to agree the screen is not as responsive as my phone and some actions require more than one touch, BUT I’m not sure if it is me on how I swipe or where I touch ( big sausage fingers)
I will say that the Core radio is by far the best most intuitive radio I have ever had. I had a very well outfitted Jeti radio system that was great, zero issues, took a bit of a financial loss selling it in order to get the Core. I would do it again in a heart beat.
I love my core Radio
Am
Old 02-19-2020, 08:34 AM
  #362
I wonder if it might not be a function of a combination of the O/S and processor speed, but in any event I've found that if I'm deliberate about my touches and don't treat it like I'm writing a text message it works consistently for me. When I'm doing model setup with a lot of touching I use a touchscreen stylus, which really helps with my fat-fingering.
Old 02-19-2020, 09:04 AM
  #363
I had trouble initially because I was pressing too hard. I find that when I barely 'touch' things go much faster and smoother though I do have to focus!
Bob
JamesKNMA (02-19-2020)
Old 02-19-2020, 09:11 AM
  #364
BarracudaHockey's Avatar
A stylus sure helps for doing a complete plane setup
Old 02-19-2020, 09:45 AM
  #365
Bob_B's Avatar
Like an Airtronics Stylus?
Old 02-19-2020, 10:05 AM
  #366
I have a friend who’s wife can’t get an iPhone touch screen to work, I do see some people struggling, but they are the ‘stabbers’ like B says, gentle touch seems to get best results.
Old 02-20-2020, 08:04 PM
  #367
tonight I installed an Igyro Sat in a foamy extra 300 to test, pretty straight forward ( love this radio OMG) first updated the PBR -7s, is this not the coolest feature ever!, then followed the instructions by PB, one question, on the fine tuning screen there is a gain value by default at 75% what does this do? I took the value down to zero and deflection seemed to stay the same based on the rotary knob position.
Thanks for reading
Angus
Old 02-20-2020, 08:25 PM
  #368
next question, abbreviations and acronyms drive me crazy so what does:
RSSI 1 mean
LQI 1 mean
I know or figure it has something to do with signal strength ??
Angus
Old 02-20-2020, 09:08 PM
  #369
My Feedback: (50)
felker14's Avatar
LQI - Link Quality Indicator from what I’ve read on PowerBox Support forum you want 50% or better. Per Richard on support forum “forgetRSSI - it´s signal strenght nut has no influence in the LQI (Link Quality)”
Old 02-21-2020, 12:09 AM
  #370
Thanks for reading
Angus
The 75% is a separate figure for each axis to allow tuning. So if your gain knob is dialled to 50% (halfway) you have 37.5% actual gain, leave the 75% and after test flying if the axis that oscillates first is the elevator, reduce the 75% on that axis.
Dave
Old 02-23-2020, 01:33 PM
  #371
Might be over thinking this, no output 1-9 but Igyro srs works on my PBR 9D, here is the set up:
PBR 9D with Igyro SRS set up on FastTrack, channels 1-8 used as servo output, channel 9 for battery, I have flaps on 5 and 6 and no output, there is power applied to the servos but no signal, signal through FastTrack to Igyro SRS 10-14 (aileron elevator and rudder) all work fine, I thought I bench tested it but probably just happy the Igyro was working and assumed channels 1-8 would work as simple outputs.
Tested flap servos with servo tester at receiver lead input
Servo wire is going in the right orientation
Its like 1-8/9 are turned off
I'm sure its something simple
any thoughts
Angus
Old 02-23-2020, 05:36 PM
  #372
any thoughts
Angus
Did a remove and re-bind nothing, put a new receiver in and problem solved, I'll speak to Powerbox about this.
Angus
Old 02-23-2020, 05:51 PM
  #373
husafreak's Avatar
Maybe redo update on the faulty Rx?
Old 02-23-2020, 08:24 PM
  #374
First thing I thought, did a refresh of 2.2 on receiver.
AM
Old 02-23-2020, 08:59 PM
  #375
Angus
Figured it out, knew it had to be me rather than this first class radio system, in general settings for some reason I changed "start output channel" at 10 instead of 1, I'll take this one on the chin.
Love this radio
Angus
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
