Powerbox Core radio and set up thread.
#426
I'm looking for some advice. I currently own a Futaba 18mz, and it is basically 10 years old, time to move it on, nothing wrong with it. And thinking of a Core
All my large models are set up with Sbus (serial)through a Emcotec DPSI bus hub. I don't use the Powerbox expanders. The DPSI bus hub handles the power requirements just fine. Lighter etc
I do understand if I go to the Core it will involve new RX's.
My question is, can I purchase Powerbox Rx's, output a serial output that my servos (Futaba Sbus2 types)in existing models will recognise. I don't want to install a power expander, and then have to PWM to the servos. I don't want to run all new cabling. I can hopefully just change RX's
Thanks muchly
Thanks muchly
husafreak (04-06-2020)
#427
Yes - he can use his wiring and Servos. All receivers have an S.BUS output which is the protocol used in this hub. S.BUS2 servos also understand the regular S.BUS as well.
From Powerbox directly...
#434
AZ, AUSTRALIA
Really nice to hear some positive comments about the Core
I admit to being a long time Futaba diehard
I have felt a 32MZ. And was extremely disappointed. Sliders on the back are in a terrible position and difficult to operate. Knobs on the front are too recessed. I'll stop!
The gimbals themselves felt really, really nice. Smooth with basically no resistance. The best Futaba has produced I feel.
Really looking forward to the Core giving me more!
Chris
Chris
#435
These gimbals are like machined butter. The sliders are in exactly the right place for my hands and the knobs, sliders, and gimbals are all field effect and machined.
Updates came out for my receivers and I updated them this morning from my radio, one of the coolest features IMO
#436
Dave is correct - the receivers can be set to output SBus.
We are using this right now to communicate with the PB Royal. The Royal will only output PWM or using the PBUS system - not Sbus.
As Dave has stated, if someone is just replacing a Futaba system with the Core, this is done very easily - just replace the Futaba receivers with the Core receivers and go into the receiver settings via a widget in the Core and change the output to Sbus.
#438
A word to the wise to be careful of a feature in mixes that I'm not sure is safe. I was flying my pattern plane yesterday after converting it to the CORE. In anticipation of needing throttle to elevator, rudder to elevator, and rudder to aileron mixes I quickly enabled them in my Tx. When I powered up to fly again I realized that all of the mixes were active and at high values! So I went back to the mixes and zeroed them out. I don't know why PB defaults to a random high mix value but I think it should default to zero when first enabled.
#440
#443
AZ, AUSTRALIA
Done the deal
Now I just have to patiently wait (hard)
At least I have time to measure all my models control throws and other important stuff. Prior to setting them all up again
Thanks to everyone for answering my questions
Chris
#444
I had a 10 channel jet running on a PBR9D by remapping the P2Bus to PWM. BUT I had an iSat gyro that I wanted to install in that jet and needed the P2Bus port back. I could have done it a couple of ways but I put another receiver in the jet, a PBR8E and plugged in the nose steering, brakes, and gear and ran power to it. (1,2,3,4) then set the 9D in the receiver/telemetry menu to start at channel 5. Then it was a matter of mapping the functions i wanted to each servo number. Then I set the gyro gain to channel 12 and assigned it to a knob, the gyro gain is a virtual channel, meaning you just setup the knob as servo 12 and then tell the gyro that it's gain feed is 12 and you're done.
So for the receivers that support it, you go to the Receiver menu
Tap the receiver you want to modify
Then tell it what servo (channel) you want that receiver to start at..
#446
Nearly - there's one more step. Using the receiver widget on the transmitter you set the 5-channel to start at channel 8. In the last photo in the post above it's shown as Output A Start.
#448
One of the things that weirds me out about this radio is that you can do things like Andy's solution above because apparently all of the receivers pick up all 26 channels all of the time. This melted my brain, but it certainly adds tremendous flexibility.
#450
Good morning,
This is my first post on the rcuniverse forum! I usually like to keep myself up to date on current affairs concerning our hobby and this forum is the place for that, bar none! I've been reading and looking for a few years but I never contributed so here's my thanks for all the help this forum gives.
I would like thank Dave Wilshere for starting this post and also to every one of you who posted informative reply's on the Poweerbox Core! I've been reading the information thoroughly and I would thank you all very much as it's insightful and inspiring! I do not fly jets but I was looking for information on the Powerbox Core!
I was a previous Jeti radio control user and I had sold my radio a couple of years ago thinking I was going to give up this great hobby. Well that idea only lasted eighteen months and I'm back into the thick of things and I would like to mention that I am also a new Powerbox Core owner. I never had the pleasure to see the Powerbox Core radio in person, or feel it my hands but I took the risk anyway knowing full well this is the future of radio controllers. I've only had the radio for a week and I must say this was the right choice I made!
