Powerbox Core radio and set up thread.
#727
When I turn on the Champion but leave the CORE turned off, all of the servos turn on and don't jerk/jump. You can hear that they are all on. But the moment the CORE is turned on, everything goes crazy with the servos.
#728
I've only got PBR-26D's. They have to be connected to a PowerBox in order to work. I've got another Champion sitting around and can see if that'll make a difference.
#730
I don’t use champion, first thing I do is hook up all devices to Powerbox Terminal and make sure software is up to date and the Champion is set to PowerBox input signal and not some other brand of input. I have found that not all devices are factory default to powerbox and that may result in your symptoms
#731
Well I think I figured it out. I moved both the RX cables from P2Bus to Fast track data. I used a separate lead from P2Bus in 1 receiver to the telemetry port in the champion. This was done just like Richard said for the older Royals in compatibility mode on the PowerBox forums. I changed the system from P2Bus to S.Bus and matched the Framerate for both receivers in the CORE to 18ms and 18ms in the champion SRS. And boom, everything works excellent right now! My champion is 3+ years old way before the core came out and that's why it wasn't working with P2Bus. My next Champion was purchased about 6 months ago so that should work with P2Bus.
#733
My Feedback: (41)
#735
Hi
I.have a Core for 2 weeks and very happy with it. Less funny part is to program all jets from scratch after being a Futaba user since I was a teen. Nonetheless, this has been very intuitive and fun programming
There is no mixer in the servos menus, that allows to mix different servos using the same funtion. The mixer only allows to use mixes, between functions, like elevator to flap, or aileron to rudder. But for example I use 2 servos ganged together in the flying stab of my aviation design Hawk. If I want to mix elevator 1 and elevator 2, it's not possible. I can do it on the servos menu, but the curbe is limited in only to 17 points in a 200% travel, meaning only 7 or 9 points are really usefull for the used throw.
Usually I match the servos using the TX, rather than the Powerbox, as PB only allows to match in 3 points. One of the things I thought the Core could do, was to match a courbe in the same funtion in 33 points. In my 18MZ I was using 17.
The lack of mixes with different servos using the same function, is really a major topic to be left unattended. I am yet discovering the TX, but don't see it being possible
B.R
Nuno
B.R
Nuno
#736
Glad you were able to get it working. Sorry I wasn't of more help but the solution is way beyond my Core experience. Have to log that issue in the memory bank as I have an older Royal SRS in my SM Tomcat, but it's buried in the shipping container it came to me in, out in my shop and I'm afraid it's going to stay there for some time.
#737
Glad you got it sorted, it is too bad you had to go through the problems though. PowerBox Should really be more proactive with helping CORE purchasers use older PowerBox products. They don't really give much info there. I don't have a Champion but when I got my new CORE I could not get it to work with my older Royal and also had to ask for help on the Support Forum. I found out I would have to use the Royal in a different mode, or send it in for upgrade. Now I am happily using it in the "degraded" mode, that is no problem, it all works well. But as you found learning how to use two PowerBox products together was anything but easy. Ideally it should not be this way. I wondered at the time why the manuals were not updated, perhaps now they are or will be.
#738
Hi
B.R
Nuno
B.R
Nuno
Now with flight modes available Flap/Elevator compensation is best dealt with using the trims since they allow some adjustment throughout the models life.
#739
What Powerbox really needs is a "Harry Curzon" who does instruction videos on YouTube for the Jeti product line. Martin Pickering has done a couple of verry good instruction videos of Powerbox products but it takes many, many moore to reach the same hights.
Jannica.
Jannica.
#740
I have to agree - teaching one self how to use the CORE is not always fun. For me the worst experiences have been when trying to understand what is meant on the PB forum. With so many translations happening the messages get lost in misunderstanding and sometimes even plain bad attitude. We definitely need a well versed English mentor to run through the basics and take on the challenges that confront all newbies to the CORE and all the other PB products - each and everyone a fantastic quality product. Just not supported understandably.
JanR
JanR
#741
When I started selling Core I wondered if I was opening myself up to a World of pain from customers contacting me every minute about set up. I’ve sold to many different levels of experience and been pleasantly surprised how well people get on with just a few pointers. Danny at PB America’s has also done some videos other than Martin that I have seen, he should be able to help people with questions on your side of the big pond.
Because the Core was always going to be a constantly developing radio it has been impossible to produce a manual covering everything as it’s released. Manuals written by anyone connected with the development are a waste of print in my experience, too much of what is required makes sense in their minds without the need to write it down.
Powerbox Expert forum answers questions in the language the question was asked in.
#742
I have been part of threads that had several 'original' language contributions - but yet all I read was English. It is absolutely incredible how many different versions the same concept can have when it is translated over and over. The way of expression in one language is not always conveyed with the same intend in another language.
JanR
#743
I agree that printed manuals are no longer needed. But online .pdf manuals are and they should be updated as the products develop. It should be a higher priority. Videos are a problem because they float around on the internet and don't get updated. Jeti may have better video coverage but that doesn't keep their owners from long discussions and Tx programming exercises on the flight line. Those Tx should come with a chair to be used for that purpose! For some reason though manuals are often left for last and forgotten. It’s not only PowerBox. It was a problem at work with Boeing’s! I don’t think engineers like to write much, LOL.
#745
The latest Core I sold today has a paper manual (also on line) showing Flight Modes, so it’s pretty up to date.
I think Richard does amazingly well answering German and English questions. I only read the ones asked in English as written German has a literal sense.
#746
My Feedback: (41)
My biggest issue right now with the number of PB CORE components, is the FREQUENT updates issued for various components. Can't they at least mention that various parts of the system have been issued software updates????
Or have I completely missed some "check box" in my PB Forum profile?????
#747
I don’t update anything that is working flawlessly with the software it has, generally it’s when I want to change something that it needs an update for using new features.
I use the Terminal not Forum. I can click on the Terminal and see what the latest software shown is.
#749
My Feedback: (9)
Screen protector
CORE SCREEN PROTECTOR
Anyone wanting a screen protector for their PB Core, these guys do it and turnaround is good and not expensive - if you order 10 then spread the cost with mates etc.
https://www.protectionfilms24.com/cu...cc8d04911e1e70
Brotect AirGlass Screen Protector custom size 75mm x 112mm, Radius: 6.0mm
Are folks using protection or flying commando?
#750
I have customers with them and without. Neither of my Core Tx have one. Here is the screen on my prototype TX that will be 3 years old in a couple of months. Not a scratch...but I look after my radios, I have customers that have new Tx’s that look as if they took them home, dug a hole in the garden and buried them...then dug up a week later!
Dave
Dave
husafreak (03-16-2021)
