Powerbox Core radio and set up thread.
#1576
Dave,
I think there may be a misunderstanding. The 'HELICOPTER' image I am referring to is not a photo of the heli I was trying to program. It is the grey phantom like image that comes up when you scroll down on the top LHS above the list of models that are programmed on the CORE already.
To put it differently; if I no want to program another model, then I can only scroll through the PLANE, CAR, BOAT and MULTIROTOR images, the HELICOPTER is gone.
How can I get it back?
JanR
JanR
#1577
There is a fairly detailed description, 2 pages, of the I Servo and its telemetry integration with the Core (and presumably Atom) in the latest RCJI. Some performance figures are included.
Excellent servo.
Excellent servo.
#1579
WAY easier. Once you do your first model you will wonder why every radio on the market isn't as easy.
I can pretty much figure out anything electronic and when someone approaches me for help with a Futaba radio I simply cringe because it takes me forever and there's no reason. Maybe if I learned it once and for all but their setup just doesn't make sense to me personally.
#1581
My Feedback: (18)
Futaba is also easy once you become familiar with it, I own both and would not personally use that as a basis for the decision. The core seems more current with the times to me, you can see this in how you setup telemetry, in the Futaba it was always kludgy. You're able to update your TX and RX via wifi with the core, no need to pull the sdcard. You have an onboard sequencer too. You could get away with minimal sequencing on the 18mz, but it was so limited, again, very kludgy. The biggest benefit for me is the integration within the PB ecosystem. You can now discover and configure your gyro in the radio, you can view how their servos are operating via a sensor too. That is all light years ahead of my last Futaba TX, an 18mz. All that said, I have not kept track whether Futaba has developed their code any further since I moved to core. In any case, there are many other redeeming qualities than easy to setup. I do agree with Cuda, instead you will wonder why you did not switch sooner.
One final point, there are a lot of cortex owners out there that may not buy into the PB gyro lineup. What I've noticed is that they have typically remained with Futaba or Jeti.
grolleman (01-31-2023)
#1582
The Atom is way ahead of Futaba, same easy programming as the Core, just a few less channels and features. Did a change over for a Spektrum iX20 owner yesterday, easiest swap ever as both jets had Powerbox Mercury units. 40 mins each model.
#1585
18 channels rather than Core’s 26 (still more user able channels than a Futaba 18MZ) Less Flight Modes (still plenty) and 2 rather than 4 Receivers can be bound to Tx (Two is same as most radios)
Atom is enough for most sports flyers.
#1586
Thank you for this explanation.
I have become much wiser again.
I also listened to Martin but my English is limited.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
JamesKNMA (02-13-2023)
#1590
Will never buy something I don't like so it will become the core.
Even though it is much more expensive.
What is the opinion on holding the transmitter?
It will be a lot heavier than a futaba and other material.
Can people quickly get used to it?
#1592
Geoff
#1593
There will be a PowerBox weekend in Bruges, Belgium, on March 10 and 11. Richard Deutsch and Manuel Kamitz with Timen Deprinz will host the forum. It will cover details of both Core and Atom transmitters.
WWW.AEROBERTICS.BE
WWW.AEROBERTICS.BE
#1594
WWW.AEROBERTICS.BE
WWW.AEROBERTICS.BE
thanks, Behzad
#1596
Know that there is someone in Nijverdal for the rest no one where I have seen it.
There is also someone in Ede.
Then I regret that I went from the 14 tg to the 16 sz. In itself an improvement in terms of setting, but the screen is difficult to see in the sun. Think the jeti would be a much better choice. But now the power box is the future I think. Double power supply etc with jets just extra security.
#1597
Just like you from the cold little country.
Geoff
#1598
Bert replied:
Its more like a fair so not possible to make it live.
Might well go myself, with wife, Bruges is a beautiful medieval town with lots of good hotels., so making a long weekend of it !
gpman (02-04-2023)
