Powerbox Core radio and set up thread.
Springbok Flyer (03-20-2023)
#1680
Hi All, thank you for your replies. It is correct. I have setup for complete shut down. I have set it up already but wanted to test it. I have Jet Cat turbines and it is easy check with that as once transmitter off, we can see the failsafe icon on GSU. But i have built a Geemo and have a X45 in it and could not see that if Failsafe Is working or not. that was my issue.
Happy spring.
Behzad
Happy spring.
Behzad
#1681
A guy had a 1/5th scale F-16 at Florida Jets and saw me in the Powerbox/Jet Cat tent and asked me to give him a hand.
It took less than 2 hours from scratch using a Core and a new Mercury SR2 with 26D receivers including flapperons,flight modes with FM specific elevator trim, gear, brakes, air brakes, lights, setting up the turbine and ready for a test flight. I heard the same thing I hear a lot when teaching Core programming "It can't be that easy!" yet it is.
CostasV (03-20-2023)
#1683
A couple of years ago I set up a CARF J-10 in the queue to fly…the model had been flown on JR so little to be done on the PB other than change the set Rx system and have a friend on the Mercury to confirm the channel mapping, it was around 25mins start to finish-then I test flew it.
The radio is years ahead of everything!
#1684
Defintely one the easiest radios to program.
The interface is reasonably well thought out.
Just a simple feature such as the way it handles 'Functions' means that what requires much more convoluted programming on other radios becomes all so simple on the Core/Atom.
jcterrettaz (03-23-2023)
#1685
Thanks for all the info you can find here.
And of course Dave fantastic what you have written. Just ordered the core.
I will first test it on a simple motor plane to get used to the transmitter and later I will fly the rebel classic with it.
#1686
Don’t over think the set up. Function menu for controls and set up options. Servo to adjust actual travel. Remember Core starts with 50% for previous set up models, for new models increase to 100% and set servo arm lengths to suit, reduce movement and add expo in the Function menu. You can easily have three options of movement and expo
Dave
Dave
#1687
My ten cents worth is when you set up the Rebel start by using flight modes. If you put your three flap settings on a three position switch using flight modes it sets you up properly for everything else. I did a few set ups before going back to that and re doing them. Basically it seems that if you want to use flight modes you should start with them. After doing what Dave said
gpman (03-23-2023)
#1689
Firmware update 3.20 is now available for the Core.....
Ensure that your OS Kernel has been updated to v2.0. If not you will need to first perform an update as per details on PowerBox's forum.
If you are already running OS Kernel v2.0 then just update the Linux app to v3.20 as normal via WiFi.
24.03.2023
Linux Application: V3.20
Transceiver: V1.44
Stickcontroller: V1.5
24.03.2023
Transceiver: V1.44
- Bugfix export Modelfile can overwrite existing model on the USB stick
- Bugfix vario settings
- Internal GPS status more detailed
- Date settings corrected
- New receiver 4.0 updates implemented
jcterrettaz (03-25-2023)
#1693
Gents,
I just got the atom and starting to change all my jets over from spectrum.
I'm setting up a new Rebel Pro with Jets munt 210. How is every setting up their turbines?
I managed to get the right pulse settings by going into Functions-Throttle-Trim as per photo. This ok or should I change it?
This is from the Jets Munt manual.The setup assumes the use of a transmitter with manual trims. If you use a TX with digital trims, is essential to use the switch in the TX programmed for the function "Throttle cut", or “engine cut” which normally has the effect of producing the “trim-down” function. Using a digital trim cause unstable idle, and delay in shutting off the engine in emergency. Check your radio manual for this before you start. Avoid using the digital trim if possible.
#1694
I think you are wrong.
On the Core/Atom simply set the throttle trim to 100 % ,trim range two steps, steps 100 % from zero to full.
Align the ECU as per Xicoy JetsMunt instructions, trim down, trim up etc and you are set.
Moving the digital trim with settings as above is just as quick as moving a mechanical trim, or even quicker !
Thats my set up on a Jets Munt Merlin and my 5 Xicoys.
Idle speeds rock solid.
#1696
This is the setup for every brand of turbine I've owned or setup for others.(Kingtech, SW, Jet Central, and Jet Cat)
80/80 on the throttle end points
Mode : Left
Trim range 20%
Steps 100%
Direction: Normal
100% on the steps gives you 2 clicks to arm, and 2 clicks to shut off.
Mode : Left
Trim range 20%
Steps 100%
Direction: Normal
Jannica (04-17-2023)
#1697
Mode : Left
Trim range 20%
Steps 100%
Direction: Normal
Mode : Left
Trim range 20%
Steps 100%
Direction: Normal
#1699
#1700
These settings worked well for the jets munt 210, thanks for your input!
100/90 on the throttle end points
Mode : Left
Trim range 20%
Steps 100%
Direction: Normal
Mode : Left
Trim range 20%
Steps 100%
Direction: Normal
husafreak (04-18-2023)
