Reload this Page >
Powerbox Core radio and set up thread.
Old 10-07-2023, 01:05 AM
  #1851
David Gladwin
David Gladwin's Avatar
I asked Richard about twin batteries on the 14. He recommended Pioneer for dual battery operation.
Other PB receivers have no dedicated battery input, simply Y leaded into a servo socket, so the 14 may also work in that way, too.
Interestingly one poster on the forum suggested one battery into the MPX and another into a servo socket, with diode protection to isolate one from another.
Over 25 years ago I was told dual battery operation required that diode separation. I started to use it, then tried without diodes and have been using it ever since with zero problems using JR,. Weatronic and PB receivers. I currently have three jets configured with a 9 ch PB receiver plus an 8. Both of those receivers have twin inputs, one from each
B sensor switch out put. So far so good !
We will see
S just a bit more during coffee time !
Last weekend I was flying my AW Hawks, both for the last time before the ageing but hitherto perfect, Weatronics are replaced with PB Competition SRs.
Total current in ground about 1.5 amps, 11 servos.
Average current in flight around 3.5 amps.
Occasional spikes of 4.5 amps as flaps travel down at mod.#speed, and at high speed with significant, but not excessive, stab. Travel.
After flaps reached fully down, servo arm in line with servo shaft, amps reduced to 3.5 ish.
So, I guess the power, current, handling of the 14 ch receiver will be way above this.
The Pioneer is rated at 20 amps.
Whatever I am flying, I like the comfort of dual batteries, even on ECUs and I use the Emcotec Ampere for the ecus, they work very well.
Old 10-14-2023, 11:58 AM
  #1852
grolleman
Ik gebruik de jeti dsm 10 voor een dubbele batterij gebruik die ik denk dat is een veilige keuze voor mijn futaba ontvanger die ik gebruik. Kan deze ontvanger nog steeds omruilen voor de powerbox-ontvanger en deze gewoon in de mpx voeren. Dan maar 2 schakelaars achter elkaar maar dubbele voeding.
Old 10-14-2023, 12:02 PM
  #1853
BarracudaHockey
BarracudaHockey's Avatar
Huh?
Old 10-14-2023, 12:32 PM
  #1854
Springbok Flyer
Springbok Flyer's Avatar
Translated
I use the jeti dsm 10 for a dual battery use which i think is a safe choice for my futaba receiver that i use. Can still swap this receiver for the power box receiver and just feed it into the mpx. Then only 2 switches in a row but double power supply.
Old 10-16-2023, 11:11 AM
  #1855
Zeeb
My Feedback: (41)
Zeeb's Avatar
Originally Posted by BarracudaHockey
Huh?
Highlight the post, right click and select "translate to English" from the menu. Or at least that's how Chrome/Google work if that's what you use. I don't know about other browsers/OS's.
Old 10-16-2023, 12:19 PM
  #1856
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Works for IOS as well with Safari......
Old 10-17-2023, 06:41 AM
  #1857
David Gladwin
My 14 ch receivers have arrived. Beautifully made with some nice features, PB have a winner here.
marksp (10-17-2023)
Old 10-17-2023, 07:56 AM
  #1858
marksp
My Feedback: (9)
marksp's Avatar
Default Remote ID
anyone with insights on if/when PowerBox might offer Remote ID module?
Old 10-17-2023, 08:06 AM
  #1859
BarracudaHockey
My guess, and this is just a guess, is that they won't.
Old 10-19-2023, 01:17 AM
  #1860
BarracudaHockey
Richard made a range test video. I hope I'm never at 9 km to find out if my radio works that far but evidently it will
The following 4 users liked this post by BarracudaHockey:
blackcat (10-20-2023), danny-p47 (10-29-2023), marksp (10-19-2023), Zeeb (10-19-2023)
Old 10-19-2023, 02:06 AM
  #1861
David Gladwin
A really excellent video from the expert. It certainly shows the serious deficiencies on that “Lighter Side” video where the presenter is totally clueless on the functioning of patch antennae.
The more I use my Core the more I appreciate its technical excellence, an opinion which seems to be shared by more and more jet fliers in the UK , judging by the numbers I see at events here.
The following 5 users liked this post by David Gladwin:
blackcat (10-20-2023), Canadian Man (11-09-2023), CostasV (10-23-2023), danny-p47 (10-29-2023), marksp (10-19-2023)
Old 10-29-2023, 08:37 AM
  #1862
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Default Seems like a good deal
This seems like a good deal for those looking for a system. I donít know the seller.
Powerbox CORE w/PBR-9D Rx in Sealed Box. Also, Lots of Extras Available If Desired
Old 11-08-2023, 11:09 AM
  #1863
DUCMOZ
Hi All, is there a video showing how to set up the crow on Core? I have gotten a little stuck.
Thank you.
Behzad
Old 11-08-2023, 01:00 PM
  #1864
BarracudaHockey
It's really not that hard.
Create a function called crow. Assign it to a switch or whatever you want to use.
Assign the ailerons to it and set the direction and amount of throw such that they both go up.
It really is that simple
Old 11-08-2023, 02:24 PM
  #1865
DUCMOZ
Hi Andy
Thank you. will give it a shot see if i can get it to properly work.
Behzad
Old 11-08-2023, 02:39 PM
  #1866
AEROSHELDON
My Feedback: (99)
Costas,
I know you are making a list so I have a couple requests:
--the servo menu deep dive (not the function menu, but the button looks the same)
--how to use aileron differential widget in flight
Thanks!!
The following 2 users liked this post by AEROSHELDON:
Jannica (11-08-2023), JetFan5000 (11-08-2023)
Old 11-09-2023, 11:53 AM
  #1867
David Gladwin
I see that PB will now be working with CHAservo, presumably to replace the MKS based I servo.
Anyone have any experience with these servos ?
Old 11-09-2023, 12:10 PM
  #1868
CostasV
CostasV's Avatar
Originally Posted by AEROSHELDON
Costas,
Thanks!!
Sure, I already have these in mind...
I was only thinking about how I will go about explaining the Function/Servo setup menu(s). I'll probably split it up into two parts ie servo setup explanation then the overall Function programming part as otherwise we can talk about this feature all day long. The Functions menu is inherently the core basis of all our model programming in these radios.
Aileron differential is pretty simple but I will explain this as well in a separate video.
Next on my todo list was a video on the timers specifically a 'how to' on setting up an advanced timer with multiple voice announcements that can be automatically spoken at various set intervals including manually triggering a timer voice announcement during countdown etc.
The following 3 users liked this post by CostasV:
AEROSHELDON (11-09-2023), gpman (11-10-2023), Springbok Flyer (11-09-2023)
Old 11-09-2023, 12:12 PM
  #1869
AEROSHELDON
My Feedback: (99)
Yes I do this on a momentary button so it will speak the time anytime I push the button, it is very handy! I will watch yours anyway because there are several ways to do this I imagine.
Keep up the good work!!
Old 11-12-2023, 02:24 AM
  #1870
CostasV
CostasV's Avatar
Timer video posted.....
Old 11-16-2023, 08:08 PM
  #1871
CobraJet
CobraJet's Avatar
Supposedly these are KST based servos. So what was the outcome or backstory with the MKS iServo? I purchased two for bench testing before installing in a jet. I also have two new MKS HBL 550 to test and both servos appear to be identical, also with no mechanical hard stop.
Old 11-17-2023, 12:18 AM
  #1872
David Gladwin
I have both, 550 and PB I servo, of these servo types. I believe that mechanically they are the same.
However, the I servo electronics are quite different, the I servo operates at 1000 Hz v 300 for the 550.which seems to give the I servo smoother and more precise operation. The I servo is programmable and includes telemetry, and optimised for use with Core/Atom.
Sad to see the I servo go it is a very nice servo indeed.
Dont know about the change from MKS to the new brand , of which I know nothing, we will see !
CobraJet (11-17-2023)
Old 11-24-2023, 06:38 PM
  #1873
khughes
I'm interested in using the combination of two 3-position switches to control various flight modes (a total of 9 flight modes between the two 3-position switches in all their various combinations).
Let's call the two three-position switches SW1 and SW2. Let's call the SW1 and SW2 positions Top, Middle, and Bottom. Now, can
SW1-top + SW2-top be Mode A, SW1-top + SW2-middle be Mode B, SW1-top + SW2-bottom be Mode C,
SW1-middle + SW2-top be Mode D, SW1-middle + SW2-middle be Mode E, SW1-middle + SW2-bottom be Mode F,
SW1-bottom + SW2-top be Mode g, SW1-bottom + SW2-middle be Mode h, SW1-bottom + SW2-bottom be Mode I.
What is the best way to accomplish this? It is possible using the Core's flight phases alone? Or would logical switches be better? Or a combination? In each of the 9 possible combinations of the two 3-position switches, various values on various controls (like flaps, landing gear, motor, motor retract, etc.) will be set per normal flight mode practice.
Old 11-24-2023, 09:18 PM
  #1874
CostasV
CostasV's Avatar
You must use a combination of Flight Mode switching and Logic Switch use to achieve the ability to switch through 9 Flight Modes with two 3-Way switches.
See my reply to your same question on RC Groups.
Old 11-24-2023, 10:44 PM
  #1875
khughes
Thank you Costas!
