No Brakes Jeti and Mercury SRS
Hello everyone, banging my head on this one, I have a Jeti DS24 and Powerbox Mercury SRS and Electron Gear with RB45 controller for the life of me I can not get the brakes to work:
Jeti, brakes are on channel 9 using spring loaded switch SG, on the mercury I have channel 9 attached to plug in "H" ( direct 9) I tested "H" with a servo and full deflection using switch SG, tested brakes at the RG45 plug end and have brakes when applied power. program RG45 and all seems to go OK ( when I go into programming mode the brakes are on?) but I can't seem to get brakes to turn on using switch SG or any other switch/slider. ( bought a new RG45 controller too)
Also on rudder output for steering, steering works when gear is up and nothing when gear is down, ( backward from what it should be) (
It has to be something to do with Jeti and the powerbox, I have another 2 jets with pro-link electric gear and Jeti receiver no issues
thanks for reading and any insight
Angus
Maybe I'm being a little impatient , I've only been at it for about 8 hrs.
Angus
I have the same setup with Xicoy elecric brakes and it works flawless. Maybe you have some old settings in your Tx from a previous model that lurks in the shadows and disturbs your programming? Try to start with a new model memory or go through all your settings? You can also try to reset the Mercury for the same reason.
Jannica
Sweden
Jannica
Sweden
With the Xicoy controller brakes and steering are only enabled when the gear are in the down position. By this I mean the controller itself has to be in “its” down position. Reverse your gear channel and all will work. If the gear go the wrong way you need to reverse the polarity of each gear connector.
Danny
Danny
Assuming the above post solves your issue, I was wondering about using the spring loaded momentary switch as I've never tried that before. How would one get any proportionality using that?
thanks for everyone's input. sometimes you can't see the trees for the forest.
Angus
