Reload this Page >
Remote operated ball valve
Old 06-28-2019, 06:27 AM
sirrom
Default Remote operated ball valve
I was wondering if anyone has ever put a remote operated ball valve in any of their jets and had it work reliably? I was trying to figure something out, but can't seem to wrap my head around how to make it work well.
Patrick
Old 06-28-2019, 08:10 AM
FenderBean
FenderBean's Avatar
This could be done by using the same fuel valves that turbines use already.
Old 06-28-2019, 09:56 AM
sirrom
Actually it can't. A fuel valve can and will let fuel get past it when fueling, I have seen it happen. I want something that will shut off all fuel flow to the motor upon command no matter the condition, but thanks for the suggestion.
Patrick
Old 06-28-2019, 10:00 AM
gunradd
My Feedback: (9)
gunradd's Avatar
Think I remember seeing people use servos to operate ball valves that we use for our engines. Pretty sure that is what Keith is talking about. I think it’s a requirement even in Australia but not sure.
Old 06-28-2019, 10:13 AM
causeitflies
causeitflies's Avatar
I think it was in the UK or somewhere in Europe that the separate remote ball valve was required. Not sure if it still is but someone will probably chime in.
There are some old posts somewhere that show how many have done it.
Old 06-28-2019, 10:48 AM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Some different solutions over the years
http://www.rcuniverse.com/forum/rc-jets-120/4679912-cnc-festo-ball-valve-mount.html
http://www.frankturbine.com/wp-content/uploads/ft_smokerventil.jpg
You'll have to copy and paste. I dont understand why rcu doesn't allow links...
Old 06-28-2019, 10:54 AM
Auburn02
Auburn02's Avatar
http://www.rcuniverse.com/forum/rc-j...lve-mount.html
Weird, it automatically inserts/formats/displays the links when I paste a URL. Are you on the mobile site perhaps?
Old 06-28-2019, 11:16 AM
LGM Graphix
My Feedback: (22)
Attachment 2264719
I'm on the desktop version for a mobile phone but not the mobile site . Strange. It does the same thing to me on a PC though.
Old 06-28-2019, 11:42 AM
sirrom
I had found the one from frankturbine, but its got a 10-12 week lead...going to look at the one from perthrc it looks just like what I need.
Patrick
Old 06-28-2019, 11:51 AM
sirrom
So feeling a little stupid. After looking at the example posted available at PerthRC and seeing part of it looking 3d printed. I decided to check Thingiverse and low and behold....
https://www.thingiverse.com/thing:2635085
https://www.thingiverse.com/thing:1696851
https://www.thingiverse.com/thing:2615298
The nice thing is I know sketchup well enough to mod it for my needs.
I will post what I come up with.
Patrick
Old 06-28-2019, 12:17 PM
Auburn02
Auburn02's Avatar
Very cool - I've got to get me one of these printers.
Old 06-28-2019, 01:39 PM
Bobneal1
My Feedback: (21)
Altecare in Canada sells a setup for servo operated ball valve.
altecarerc.com I believe.
Bob Neal
Old 06-28-2019, 06:43 PM
Boomerang1
Boomerang1's Avatar
To answer your original question - yes, I use servo operated ball valves.
A requirement for turbine operation in Australia (since no longer required) was a method of remote shutting
down of the engine independent of the ECU. This resulted in availability of all sorts of gadgets to cut the power
supply to the pump. Also required is a manual fuel shut off to the turbine - a ball valve.
A friend who got me interested in jets thought why not just put a servo on the same ball valve. The servo will drive
the valve shut in an emergency but still let it be used manually to open or close. The servo will not open the valve
again, pointless really once the engine has shut down.
Simple to make using readily available parts.
Old 07-01-2019, 05:45 AM
Doug Cronkhite
My Feedback: (34)
I've been playing around with the Monoprice Mini 3D Delta while I'm out here in Afghanistan.. $200 from Amazon.. It's a FANTASTIC small format machine. Print quality is amazing. Build area IS small though.. but for stuff like this it's perfect.
Old 07-02-2019, 02:39 AM
FalconWings
My Feedback: (57)
FalconWings's Avatar
Patrick
Use two in series instead of one.
David
