Reload this Page >
Best jet for rough grass field?
Old 07-06-2019, 04:20 PM
RC_MAN
Default Best jet for rough grass field?
Due to the poor weather our grass runway is in less that ideal shape. Is there a jet out there that has a robust design and gear to handle this. I can go as high as 55 Lbs of thrust.
Old 07-06-2019, 07:59 PM
sysiek
My Feedback: (176)
sysiek's Avatar
Aviation design super scorpion
Old 07-07-2019, 02:59 AM
GULDUKAT
I was in the same boat as you. I used to fly out of a field that had a 400ft runway and the grass was cut once every 3 weeks.
As such my jets had to be capable of short take off/landing and also high enough with big wheels for the grass.
My 122" Feibao Swordfish's landing gear was the best - never an issue (5" wheels)
My 122" CARF Mephisto was also not that bad but it picked up some grass every now and then. (4" wheel)
Old 07-07-2019, 04:43 AM
tp777fo
My Feedback: (28)
tp777fo's Avatar
FB Dolphin L
Old 07-07-2019, 05:31 PM
RC_MAN
Thanks for the info, I really appreciate it.
Old 07-08-2019, 04:57 AM
GULDUKAT
Originally Posted by tp777fo View Post
FB Dolphin L
+1
Old 07-08-2019, 05:24 AM
ltc
CompARF CT-114 Tutor with trailing link gear and large tires is another option perhaps? Of course with any grass field, you have to be careful of the nosegear strut 'digging in' if you accidentally run into a hole.
Old 07-09-2019, 12:42 AM
Ceeray
Carf Eurosport. Lands and takes off with low speeds and with trailing link struts it can handle grass.
Old 07-09-2019, 03:36 AM
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
I think it helps to know your budget in order to recommend a jet. There's a big difference between a $5K, $10K, or $15K jets.
Old 07-09-2019, 12:51 PM
AngusMc
Im in the same situation, looking at the Havoc or Havoc SS
Am
Old 07-09-2019, 02:25 PM
tymt
I have 70 flights on a Havoc this year off of rough grass. No issues so far.
Old 08-05-2019, 03:22 AM
Tom ling
Not as exciting as above, but I can highly recommend the off roading ability of the Xcalibur range. My mid size has something close to off-road suspension :-)
Old 08-07-2019, 05:34 AM
Quandry
Boomerang Sprint V2 is ideal for grass/rough strip - 80 to 120 size turbine
Eurosport also a good option but flies best between 140 to 180 turbine size
