Skymaster (X-Treme ) F-100 Super Saber
My header ? its just sightly aft of the cockpit seat on left handside
The 1st flight did have the fuel tanks on but it seems they cause more trouble than what they are worth lol .. for the 2nd flight tanks will be removed and CG readjusted, also flying here in Colorado does not help due to 5500ft Elev, especially on a hot day
whj1961 (08-08-2020)
I might try your 345mm front the leading edge at root but I am assuming that's with your 4 tanks installed? if that's the case might go to 350 mm? or you think that's pushing it? even though the SM manual says you can go back all the way to 360 mm
Also Kevin do you have any videos you can share of flying and landing your F-100?
Also anyone recommend a CG balance without having to spend a fortune since I will be only using it for my F-100?
Balanced with tanks on at 345 from leading edge
#34
120’s and 140’s sound a little anemic. Especially at Colorado elevations.
And Saeid, yeah make sure you don’t have anything that can get caught up in your gear. Those airlines look awful close to your mains.
Oh and F-100’s love gyros so add one! My hun likes about 30% on a cortex in all flying conditions, but of course, yours might be a little different.
#40
Hi,
after F-100 belly landing i just fly it one time and its really good flying machine , but i have to forget how did i land the F-22 and get use to this one
here is youtube link
#42
My Feedback: (167)
Anyone have a picture of the location of the screw that is used to tighten the rudder to the fuse. What I need is something that shows where the hole is located in the fuselage so I can insert the Allen wrench to tighten the screw against the rudder carbon shaft.
Unfortunately they did not drill the hole in the fuselage from the factory and now locating it up inside the fuse is close to impossible.
I posted in another F100 thread also but want to put it here also to see if I can get some help.
#43
I cover it with bullet sticker
hi , I covered it with bullet hole sticker
Abedinpour (08-08-2020)
