Reload this Page >
Rebel Hot by Comp Arf
Old 07-30-2020, 01:36 PM
  #526
Bob_B
Bob_B's Avatar
Originally Posted by ltc View Post
The only thing I’ve read online is that the ER30 are heavier than the JP
No idea how much is gear, strut or controller. It’s a bit like turbine weight differences between turbine only or installed system weight
I have a deposit on a custom color swap Rebel
Hot (September delivery for winter build)
In order to “build and fly light” I am planning JP retracts/struts but will not use their controller; instead I will use a Xicoy (better braking performance and perhaps a bit lighter due to case design differences)
Go with the Stock gear and then order the Xicoy LGC 13 gear controller, it weighs about a third of the JP Unit. I run my X45 and the gear from a 2S 2000 lipo approved by Gaspar and has worked perfectly.
I did not even have to change the value in the Gear Controller.
bodywerks (07-30-2020)
Old 07-31-2020, 09:42 PM
  #527
Dave Wilshere
Not easy to paint on the Hot, but CARF worked it out...looks sweet.
Dave
bodywerks (08-01-2020)
Old 08-01-2020, 02:07 AM
  #528
bodywerks
bodywerks's Avatar
Holy cow! Being that I know what the upcharge was for that scheme on the classic, I don't even want to know what it was on the hot!
Old 08-01-2020, 03:39 AM
  #529
chevronflyer
My Feedback: (9)
Wonder if they would do the art scholl chipmunk scheme on a rebel classic and the charge? 🤔
  #530
Dansy
My Feedback: (53)
Dansy's Avatar
The only thing Iíve read online is that the ER30 are heavier than the JP
No idea how much is gear, strut or controller. Itís a bit like turbine weight differences between turbine only or installed system weight
In order to ďbuild and fly lightĒ I am planning JP retracts/struts but will not use their controller; instead I will use a Xicoy (better braking performance and perhaps a bit lighter due to case design differences)
ĎThe electron might be a little heavier.....not sure but probably, on the up side...you will never have to get any additional parts to make it work efficiently.....or repair down the road...if your like me and never sell planes...
Old 08-01-2020, 03:58 AM
  #531
Bob_B
Bob_B's Avatar
I think the struts of the Er30 Set is where the extra weight is not the retract units.
I have 6 hours of operation on my Hot and retract units have been flawless.
I switched the gear controller to the Xicoy LGC 13 when i did the build.
Old 08-01-2020, 10:39 AM
  #532
Dansy
My Feedback: (53)
Dansy's Avatar
ĎWell last time I got a er30 set from Electron USA it was $700 and I didnít need to buy an additional $199 unit to make it work...is all Iím saying, let see in 2-3 years....Iím talking long term...I donít sell my jet so my Electron could also be recycle.....as an example, my Harlock Viper retract are now in the mini T-1....just had to change a few parts....
Old 08-01-2020, 10:45 AM
  #533
ltc
The JP retracts plus controller from CARF are shown at $399 USD, so even if you add $100 for a Xicoy LGC13, it’s still less expensive (and presumably lighter) than ER30’s at $700 installed
https://carf-models.com/en/products/...jp/parent/4286
Old 08-01-2020, 10:47 AM
  #534
ltc
Also FWIW, there is now a new stock scheme for the Hot ... the Infinity scheme
$100 up charge over the stock launch schemes
https://carf-models.com/en/products/...ge/parent/4522
Old 08-01-2020, 10:52 AM
  #535
FenderBean
FenderBean's Avatar
The JP retracts plus controller from CARF are shown at $399 USD, so even if you add $100 for a Xicoy LGC13, itís still less expensive (and presumably lighter) than ER30ís at $700 installed
I get a lot of folks buying the LGC12-15 to replace the JP controllers, hard to keep them in stock and at 399 for the JP controller Im not sure why u would go that route since the LGCs are much cheaper.
Old 08-01-2020, 11:17 AM
  #536
Dansy
My Feedback: (53)
Dansy's Avatar
‘I think the current price list for the LG13 Xicoy is $199.00........so your at $600...
Old 08-01-2020, 11:39 AM
  #537
Dave Wilshere
You guys need to read what is written!
Old 08-01-2020, 12:03 PM
  #538
chevronflyer
My Feedback: (9)
awe come on !!!!!
I would have purchased that one instead dang it
Old 08-01-2020, 01:00 PM
  #539
ltc
Originally Posted by chevronflyer View Post
awe come on !!!!!
Sorry!
I donít know when CARF added it.
i know I first asked about a color swap on a Rebel Hot back in October/November 2019 and it was just accepted a month ago.
Old 08-01-2020, 01:03 PM
  #540
ltc
My bad
I was looking at the price of 75 Euro on the Xicoy site and rounded it off to $100 USD for this discussion.
https://www.xicoy.com/catalog/produc...roducts_id=266
I had no idea it was now $199 USD, sorry
Edit... I think I know where $199 came from
The LGC15 is $199
Thr LGC13 is $102 USD and the LGC12 is $85 USD
So the JP retracts from CARF for $399 plus a Xicoy LGC13 would be about $499 compared to 525 Euro ($620 USD) for a set of ER30 with an RB45 controller
https://www.electron-retracts.com/pr...ebel-hot-carf/
$120 less for JP plus lighter.
Most of the JP complaints are based on controller/braking issues AFAIK
Old 08-01-2020, 04:59 PM
  #541
felker14
My Feedback: (50)
felker14's Avatar
FYI Electron Gear Set weight with GS-200 is 765g on my el cheapo digital food scale. Everything weighed that will be installed in plane. Might go +/- a few grams I weighed all wiring that was in box. Steering servo not included in weight.
Old 08-01-2020, 07:23 PM
  #542
bodywerks
bodywerks's Avatar
Great. Looks like I got HOSED. I was the first in the states to get a Rebel in that infinity scheme, on a 2M classic and a Pro. I was charged a $500 fee to put that scheme on the just classic!!!
Old 08-01-2020, 07:26 PM
  #543
bodywerks
bodywerks's Avatar
That price is for the gear, wheels, brakes, AND controller! The JP controller itself is only like $25...
Old 08-02-2020, 04:27 AM
  #544
Dansy
My Feedback: (53)
Dansy's Avatar
My bad
The LGC15 is $199
The problem is that, only the LG15 is programmable And maybe the new LG19 pro.....the other one are specific to gear sold with it......when I was running JP I change the controller to Xicoy, back then it was still $175......so not cheap and it marginally fixed the brake issued I had, and after a few years start having more thing to fix on the gear...motor and bearing falling apart....
Old 08-02-2020, 04:29 AM
  #545
Dansy
My Feedback: (53)
Dansy's Avatar
ĎAhah early adapter...I got hosed as well on 2 custom scheme 600 each from a different manufacture.....I buy them white now.....And paint them myself..
bodywerks (08-02-2020)
Old 08-05-2020, 02:09 PM
  #546
jvaliensi
Hi,
Can the LGC13 be programed with the ECU that comes with the X45?
Old 08-05-2020, 02:11 PM
  #547
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by jvaliensi View Post
Hi,
As far as I know only the LG15 can be programmed......at least the reason I purchased a couple of them a couple years ago....
Old 08-05-2020, 03:29 PM
  #548
Bob_B
Bob_B's Avatar
Hi,
YES the LGC 13 can be programmed with the handheld from the X45
Old 08-05-2020, 03:36 PM
  #549
jvaliensi
Thanks Bob B. That is one mighty nice flying site you have at Rosewood!
Old 08-05-2020, 04:04 PM
  #550
Bob_B
Bob_B's Avatar
Yes we are very fortunate!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
