Reload this Page >
Rebel Hot by Comp Arf
Old 08-05-2020, 05:10 PM
  #551
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by Bob_B View Post
YES the LGC 13 can be programmed with the handheld from the X45
Really for the Amps and time?
ok just look at the web site....I should have read this before, not sure why I purchased the LG15....I never used the gyro....and door can easily be done In the sequencer....Thank’s
Old 08-05-2020, 05:50 PM
  #552
Bob_B
Bob_B's Avatar
Glad I could help,It came recommended by F1 Rocket. He knows his stuff!
Old 08-06-2020, 01:04 PM
  #553
jvaliensi
The instructions recommend SAVOX SG1260HV servos. I like ProModler DS160CLHV. They are about the same spec, but the ProModler is 16mm wide, whereas the SAVOX is 15mm.
How tight is the servo fit? Do you think the 16mm will fit in.
I like the bigger SAVOX servos, but the thinner and smaller ones have not been good to me. I've beat the crap out of the 20mm SAVOX in RC cars and they last.
Old 08-06-2020, 03:44 PM
  #554
LimitDwn
My Feedback: (21)
Hey Bob,
Question on the LGC 13 controller, I know that you can limit max amps based on manufacture gear recommendation, have set you max amps to the JP max recommended on your LGC 13 controller? And if so what amp setting did you set the controller to? Iím running one in a T1 mini and have one in my Hot build.
Robert
Old 08-06-2020, 04:42 PM
  #555
Bob_B
Bob_B's Avatar
It is working fine with stock values.
I now have 6 hours on the model and the gear have worked perfectly.
Old 08-06-2020, 07:00 PM
  #556
bodywerks
bodywerks's Avatar
Originally Posted by LimitDwn View Post
Hey Bob,
Robert
I an set st 0.6 amps on the lg15 for the Rebel. Several dozen flights no issue. I set the Carf ultra flush jp retracts value to 0.7 amps, also no issue. I believe factory default is 1 amp. Too high, imo, b but I believe several have not adjusted it and aren't having a problem.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
