Reload this Page >
Rebel Hot by Comp Arf
Old 10-09-2023, 04:02 PM
  #1301
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by natxo
I have logged more than 60 flights on my rebel, and after solving those small issues i had with my retracts, everything has been working great and i'm really enjoying the plane.
My cg is still to forward and i fly with up trim to get level-flight, now i wanted to tune it sending the cg backwards (to the point that Dave told me).
One option as i don't want to add weight in the back is to reduce the RX battery (i currently have a li-ion 3300 jeti), the 2600 jeti li-ion weights the same so not an option....
I have a 2s 1600 SLS lipo that i can try (aprox 40grs less weight), but i'm scared if its too low on capacity.... how many flights i can expect on that one? Its too low to be safe?
https://www.stefansliposhop.de/en/ba...60c::1004.html
Regards,
Jose
I would just check the CG with the 1600s and if its good, try them for a couple flights, they are good size for that jets.you will see how many flight you can do.just check after every flight right after shutdown,,,,
Old 10-10-2023, 02:22 AM
  #1302
Dave Wilshere
I have 2 x 1300mah packs along side the fuel tank, using MacGregor servos and a Pioneer I have 8-10 flights on a charge
D
Old 10-10-2023, 02:28 AM
  #1303
BarracudaHockey
BarracudaHockey's Avatar
I fly mine on a pair of 1350 Lipo's from Pulse, plenty of capacity for a day of flying, I use maybe 200 mah per flight.
Old 10-10-2023, 11:09 AM
  #1304
natxo
Thanks to all, i understand that people that use dual battery use a device that share current from both batteries so for example a pair of 1350 equals to 2700 in total.
I tested today and was able to do 6 flights on one charge (with safe reserve) and i needed to to a fast charge at field, but overall not bad. 10 more flights to log
CG is much better, elevator is now maybe 1mm up or less.
Old 10-10-2023, 11:34 AM
  #1305
BarracudaHockey
Yea, mine has two small lipos with a Powerbox Pioneer.
Old 10-12-2023, 03:56 PM
  #1306
noahb
My Feedback: (67)
Does the rebel hot have any bad flight tendencies? Like dropping a wing on stall vs the nose dropping? How is knifedge flight? Lots of coupling or just a tad?
Old 10-13-2023, 05:36 AM
  #1307
why_fly_high
My Feedback: (19)
Knife edge is great with minimal coupling. Mine will drop a wing if you if you get it slow and get agressive with the elevator. That said, mine has never surprised me with a dropped wing. Every time it has happened I saw it coming or was like, "Well, I deserved that." It is a great jet for its size.
Old 10-13-2023, 06:05 AM
  #1308
noahb
My Feedback: (67)
Thanks for the information
Old 10-13-2023, 07:09 AM
  #1309
BarracudaHockey
Its a semi symmetrical airfoil so yea, there's a little coupling and that's also dependent on CG but nothing I don't automatically compensate for and its not much.
Same thing above with the stall, it can catch you but only if you're doing something you shouldn't be.
Old 10-13-2023, 07:54 AM
  #1310
noahb
My Feedback: (67)
Thanks for the feedback guys. Would you recommend a 70 or 85 size turbine? I have flown f15, f16, vipers, boomerangs(most flavors) etc. Would like a smaller well behaved jet, but has good landing habbits but relatively fast...170mph or close.
Old 10-13-2023, 08:34 AM
  #1311
jvaliensi
Anything from 45N to 100N turbine will work.
I started with an X45 and tried to make it as light as I could. It flew great. Then my friend got one and put a 100N in it. Wow, he likes to fly fast. So, I replaced the X45 w/ a X90 and although its a bit heavier, it is funner to fly. It does have a higher stall speed and landing speed but nothing out of the ordinary.
A X60 or K65G4+ would be a good balance between power and weight.
The Hot is the strongest of all the Rebel collection.
Old 10-13-2023, 08:41 AM
  #1312
noahb
My Feedback: (67)
Does the infinity scheme tend to sillioute in the air?
Old 10-13-2023, 09:02 AM
  #1313
BarracudaHockey
Mine has a SW60 and its a nice matched combination. I've seen one with a SW80 and if you like to go really fast then its zoom zoom.
Cloudy skies make that color scheme turn black.
Old 10-13-2023, 09:18 AM
  #1314
natxo
I have one with a x45, my field is not very big area so something faster will be hard to fly.
Mine is standard orange and really pop with a bit of sun, very visible
Old 10-13-2023, 09:36 AM
  #1315
noahb
My Feedback: (67)
Natxo thanks for the feedback.
Old 10-13-2023, 09:53 AM
  #1316
natxo
Forgot to mention that now as others mentioned there is the xicoy X60, i will choose that one instead the X45 right now... having an extra punch wont hurt.
It can land very very slow (i uploaded a landing video to google drive, note i'm not a pro pilot), overall is a great airplane
https://drive.google.com/file/d/1PjT...ew?usp=sharing
Old 10-17-2023, 11:45 AM
  #1317
koenvlieg
I'm preparing mine with the Xicoy x60, cm jets kevlar fuel tank 1.2 L and a Hab pipe.
I still have the original fuel tank, but wouldn't use it becaus it's relative long and will have some effect on the cg.
Old 10-17-2023, 12:12 PM
  #1318
ltc
Can you safely use an X60 with the (single wall) HAN pipe?
Old 10-21-2023, 10:33 AM
  #1319
koenvlieg
Today I did a ground test and everyting was ok with the turbine/pipe combination : they sell the same pipe for the kingtech k55/k70 so it should work
The plane with full hopper weights about 5650 grams, the pipe only is 70 grams : the original about 180 grams. The cm jets 1.2 L tank witch is on the cg weights about the same as the original 1.8 L about 160 grams. I used multiplex multilock for the wings.
What I don't like is that I ask a kit for the x60, they give a 'x45' kit, it took a lot of time to modify it for the x60 and they let me pay 178 euro ( excl shipping cost ) in stead of 138 euro.
Old 10-21-2023, 03:12 PM
  #1320
ltc
what did you have to modify for the x45 kit from hab.se to fit the x60?
Old 10-22-2023, 11:42 AM
  #1321
koenvlieg
I made the distance between the two separate mounts a bit smaller ( diameter x60 is 8 mm more than diameter x45 ) and make that the tubine mount is fixed at the end of the two separate mounts in order to have more air for cooling. Today was maiden flight and it was succesfull.
Another thing I wan't to tell is that ( see picture x45 #1311 ) you can not make the two fixation holes in the inlet hopper on 180 , becaus the inlet hopper will be out of center of the tubine or you have to do as I did : one side of the tubine mount on top of a mount, the other side under the mount
Old 11-10-2023, 06:10 PM
  #1322
noahb
My Feedback: (67)
So I ordered the infinity scheme. Picked up today from freight company. Not sure if these are updates, but after reading this entire thread thought I would mention a few things that are different then older rebel hots.
1. The control horns on mine are sized appropriately for the supplied clevis. The flap control horn clevis is tight. Dont need to fill in hole or go with mpjet clevis.
2. The msin fuel tank has a machined screw in fitting with oring for a seal. Also includes festo type connectors for main and vent.
If this is already general knowledge then ignore this post.
Old 11-14-2023, 02:42 AM
  #1323
noahb
My Feedback: (67)
Question, Is it OK to use the stock plastic servo arms? I have both the stock plastic and small aluminum clamping type arms that will work.
Old 11-14-2023, 09:52 AM
  #1324
jvaliensi
I used the plastic arms that came with MKS 747 servos with good success. The plastic arm works good with the metal clevis that come in the kit. If you want metal arms - I found the ones Futaba sells work well too, as the holes in the arms are about 0.062" and match up with the clevis.
Old 11-14-2023, 10:15 AM
  #1325
BarracudaHockey
I used the carbon arms from MKS on my 747's
