Reload this Page >
SM 1:7 F4 gear
SM 1:7 F4 gear
Old 08-26-2019, 12:30 PM
ron ron
Default SM 1:7 F4 gear
I am interested in the SM 1:7 (2.5m) F4, but REALLY DON'T want to use the pneumatic retracts.
Does anyone know if it is possible and which modifications are needed to fit in an electric retracts? (preferably the electron ev-50)
Ron
Old 08-26-2019, 02:08 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Hell, the gear is the best part of the SM F-4 kit. They work flawlessly and look great. Save your money.
Old 08-26-2019, 04:19 PM
Kevin_W
I think it would be possible to convert the Skymaster retracts to electric.
Old 08-27-2019, 12:57 PM
kevinthoele
I have two of them and the air works great. I would think the retract could be converted to elecric
Old 08-28-2019, 11:41 AM
ron ron
SM's struts (no intention to replace those) will fit the electric retracts, but not sure if the retract have enough room in the wing.
Anyone knows the wing thickness where the retracts mount and if there is some room inside the wing to fit in something longer toward the tip?
Old 08-28-2019, 02:34 PM
kevinthoele
I took a quick measurement and the gear are not mounted flat. The rear plate is closer to the wing skin then the front plate. The front plate is approx. 30mm to wing skin and the rear approx. 25mm to wing skin. There is a little space before the wing tip which tilts up.
Old 08-31-2019, 11:48 AM
ron ron
opps.. tried to upload a picture the wrong way..
Kevin, thank you very much for measuring. Looks like the ER 50 is a no go but the ER 40 might fit. The ER40 is rated for up to 17kg. A bit on the edge..
ER 40 dimensions: https://www.electron-retracts.com/er-40evo/
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
