Reload this Page >
CARF REBEL 2m
CARF REBEL 2m
Old 07-30-2021, 10:02 AM
  #451
A7Bldr
My Feedback: (40)
Hey Dave, its been done in an EDF version now!
Don't want to start a debate, but some of us have Turbine restrictions to live with.
Jim
DenisFerrari (12-21-2021)
Old 07-30-2021, 11:35 AM
  #452
Dave Wilshere
Seems to work well. What dia is the fan?
Heli3Dmax (08-04-2021)
Old 07-30-2021, 02:18 PM
  #453
jvaliensi
I wonder if the added vents behind the canopy are necessary?
Old 07-30-2021, 03:16 PM
  #454
MarkF
The intakes are not big enough to feed the fan as they are so yes, the vents are necessary.
Old 07-30-2021, 05:39 PM
  #455
A7Bldr
My Feedback: (40)
He's using a 128mm Vasyfan.
The following 2 users liked this post by A7Bldr:
DenisFerrari (12-21-2021), Heli3Dmax (08-04-2021)
Old 07-31-2021, 05:46 AM
  #456
Agrav8ed
I was under the impression that for an edf the intake sweet spot is 90% of the fan FSA. I am surprised the rebel intakes are not large enough.
Tone
Old 07-31-2021, 06:39 AM
  #457
Dave Wilshere
Exit 90% maybe, inlet needs lots of air. I think the Rebel series inlets are a little small for turbines!
The following 2 users liked this post by Dave Wilshere:
Old 07-31-2021, 09:40 AM
  #458
Agrav8ed
From Schluber
...For very fast Jets it is possible to minimise the inlet up to 90% FSA in order to avoid overloads at high speed due to congestion at the inlet area tube.....
Thrust tube exit can be down as low as 70%. However, the lower you go, the higher the efflux speed and the faster your jet will go theoretically. But it cost static thrust and will take longer to get there. 90% FSA on the thrust tube exhaust is considered a good middle of the road between static thrust and speed.
I love my turbine Rebel and would not go back, but I think it's pretty awesome that someone made a electric version of the Rebel. To my knowledge it's the lightest 2m composite Rc jet in the size so it makes a great candidate. Well done.
Tone
Old 07-31-2021, 10:10 AM
  #459
jvaliensi
In any case, the builder did an excellent job of adding the vents.
Old 07-31-2021, 10:54 AM
  #460
Dave Wilshere
Originally Posted by Agrav8ed
From Schluber
Tone
I worked very closely with Daniel for several years. I also converted a CARF Hawk to EDF with a DS-94 and he said it had the best performance he’d seen in that conversion….lots of little tricks to get that to work even from a short grass strip and fly for 7 mins
Old 07-31-2021, 12:11 PM
  #461
Desert Fox 1
Cheers!
Desert Fox 1
The following 2 users liked this post by Desert Fox 1:
DenisFerrari (12-21-2021), skunkwurk (08-27-2021)
Old 08-04-2021, 02:35 AM
  #462
Heli3Dmax
Hello gang! I am the builder of the EDF conversion 2M Rebel. I got my account fixed and will post all the details soon.
A7Bldr (08-04-2021)
Old 08-04-2021, 07:15 AM
  #463
N4S
Originally Posted by Desertlakesflying
I used Hysol to do my servo holders. 300 flights in with no issues.
Good to know! I just got some Hysol 9462. There are so many different Hysol, which do you use?
Old 08-04-2021, 07:16 AM
  #464
Dansy
My Feedback: (53)
Dansy's Avatar
9462 is a good one for that use….
N4S (08-04-2021)
Old 08-04-2021, 07:17 AM
  #465
N4S
Originally Posted by jvaliensi
I like to see how others install the equipment in the airplanes, so I'm sharing mine.
Great pics! Thanks for sharing!
Old 08-04-2021, 07:33 AM
  #466
N4S
I attended a warbird event at my local club and met a guy that makes custom harness and cables/connectors. I had him make the harnesses for the wings and also servo extensions with 20 AWG wires for my Rebel. It came to $69 including shipping which I thought was a good deal. His name is Ray and his email is [email protected]. I thought I share his info in case someone else is interested.
Old 08-19-2021, 04:02 AM
  #467
skymaster68
Hello Rebel Pilots!!
anyone has the REBEL lettering file and letter size info??
I want to place them under the wing on a 2m and a Pro….
thxs in advance!
Old 08-27-2021, 10:39 AM
  #468
jvaliensi
I purchased a 3l CM Jets tank for my Rebel. The CM Jet tank is shorter and wider compared to the long cylindrical tank CARF supplies. Because of the dimensional differences, the CM Jet tank's CG is approximately 75mm closer to the aircraft CG point. So, the aircraft CG will shift rearwards less during flight as fuel is consumed as compered to the CARF tank. I think this make the CM Jet a better design. However, few folks (if any) have issues with the stock tank, this only makes me happy as an engineer
chevronflyer (08-27-2021)
Old 09-09-2021, 05:26 AM
  #469
h8t2crash
Has anyone used Carf touch-up paints after a repair? Do you need to clear coat them? Did they match? How long did it take to get them?
Old 09-19-2021, 11:46 AM
  #470
cng
Default Rebel 2m
Originally Posted by dmac
Carf. With Swiwin 140.
Just curious how your Rebel 2m flies with the Swiwin 140? I plan on doing the same setup
Craig
Old 09-19-2021, 05:05 PM
  #471
Desertlakesflying
My Feedback: (28)
Looks like 320 some flights is all the JP retracts are good for. LOL
I have new units on the way.
Pretty good life with as much dirt flying as we do.
Old 10-23-2021, 11:58 AM
  #472
Dave Wilshere
Not the smoothest video, but most of a flight from today with ‘old boy’ Andrew Perkins example powered by a JetCat P-130Rx ( no part of this flight uses full power)
DenisFerrari (12-21-2021), skymaster68 (10-23-2021)
Old 11-23-2021, 11:52 AM
  #473
Dave Wilshere
More Rebel 2m models for the growing fleet in my local club. Std Orange scheme that will be JetCat P-140Rx powered and Infinity scheme ARF Plus with the new tank fittings that will have a JetCat P-130RX. Both will be Core/Powerbox throughout
Old 11-23-2021, 12:57 PM
  #474
ltc
Dave
When did they switch fittings?
Is this across the whole Rebel line or across the CARF product line?
Was there a problem or reason?
Old 11-23-2021, 01:43 PM
  #475
Dave Wilshere
It’s just happening now, so it depends when the kit was made. No problem with the original system, just the fact that people don’t want to ‘make’ things. There are other advantages to the new system.
