Reload this Page >
CARF REBEL 2m
CARF REBEL 2m
Old 12-14-2021, 08:08 AM
  #476
N4S
Hi folks,
Does anyone have the paint codes for the Rebel? I have the Launch Scheme Orange.
Old 12-14-2021, 11:59 AM
  #477
Dave Wilshere
There are no codes, CARF mix paint in Thailand to suit requirements.
Also because of the layered painting in the mould shades change, go to a paint shop and have the part scanned, it will be perfect then.
Old 12-14-2021, 12:08 PM
  #478
Agrav8ed
Originally Posted by N4S
Hi folks,
Some auto parts stores like Advance will custom mix paint. They are pretty good. It may be worth a shot if you cannot get something from Carf.
Tone
Old 12-14-2021, 03:10 PM
  #479
Dave Wilshere
You can order the CARF paints from the site also.
Old 12-14-2021, 08:24 PM
  #480
N4S
Guys, thanks for your replies!
Mike from CARF confirmed they don't have paint code. CARF stocks touch up paint and hardener in the US for the most popular colors and they are $19 per color and for the hardener.
Old 12-15-2021, 05:56 AM
  #481
h8t2crash
I have been waiting two months for Ray Labonte to ship my paint and hardener.
Old 12-15-2021, 08:58 AM
  #482
N4S
I had a rough landing, I scoffed the nose and one of the wing tips. The spar tube is slightly bent. CARF doesn't stock spar in US. It looks like an aluminum tube, 30mm in diameter and about 990mm long. Any ideas?
Old 12-15-2021, 09:05 AM
  #483
smcharg
smcharg's Avatar
If you're interested, look at dragonplate.com. They make amazing carbon fiber tubes and, of course, they're lighter. If you purchase, make sure to use pultruded tubes as the carbon fiber runs lengthwise and provides maximum strength. I love this company. I teach an Aerospace class at Texas A&M and I buy these all the time for my students.
Old 12-15-2021, 09:11 AM
  #484
jvaliensi
Amazon Amazon
I'd buy two and load test it to 10g before using this.
Old 12-18-2021, 10:39 AM
  #485
N4S
Default Roll wrapped CF Tube
Guys, thanks for your replies! I got a 30x26x1000mm 3K roll wrapped CF Tube from an eBay vendor called US Warehouse. From what I gather, roll wrapped CF tubes are stronger then pultrusion tubes.
Old 01-11-2022, 02:05 AM
  #486
rsdeus
Default Fct
Originally Posted by skymaster68
it has a 160 turbine migh that be the difference, and also who knows what size UAT and equipment it has... 🤷🏻‍♂️
i can weight mine with a 120 and a 100cc Uat from Fct next week in case if you still need the info, I dont run any pwr box or so, just 12ch rx, wireless switch and a cortex pro, 2 2600 jeti lion Batt and a 2100 mah liffe...
Hi, Im thinking to use fct uat in my rebel too, are you using? Is working fine?
Old 01-15-2022, 06:11 AM
  #487
Dave Wilshere
Another Rebel 2m test flight this morning. Most of the equipment has come out of a Wizzard, so JetCat P-140Rx with JR servos and Electron gear. Powerbox Core and Mercury. I had the gyro set in a few passes. Like all of our models it uses a Standard MAP bubble trap and felt clunk in the main tank.
Happy owner Luke smiling in the cold foggy conditions.
The following 5 users liked this post by Dave Wilshere:
DenisFerrari (01-15-2022), Jannica (01-17-2022), Kenrico (01-15-2022), skymaster68 (03-23-2022), Viper1GJ (03-23-2022)
Old 03-23-2022, 02:15 PM
  #488
Desert Fox 1
Cheers!
Desert Fox 1
The following 2 users liked this post by Desert Fox 1:
DenisFerrari (03-25-2022), Viper1GJ (03-23-2022)
Old 03-25-2022, 06:08 AM
  #489
Len Todd
Originally Posted by h8t2crash
Has anyone used Carf touch-up paints after a repair? Do you need to clear coat them? Did they match? How long did it take to get them?
I have used CARF touch up paint. The colors match pretty good. I did not bother to clear coat. Even the black lines over the yellow base turned out fairly smooth. It is kind of a PITA figuring out how much thinning is needed though. With the small quantity provided, I was hesitant to use the paint for testing. So I just went with a first guess and it worked. You do have to stick to their drying and recoat times. I had to start over once. I ended up leaving the paint set for almost a week before I painted over it. Probably overkill, but when you have all winter to paint, waiting is not an issue. At the time, Dreamworks RC had some specific instructions for mixing, thinning, etc.. Not sure if the instructions are still on their site or not.
Old 04-03-2022, 10:22 AM
  #490
DieDuenneSuppe
Hey guys, after flying for many years 3D aerobatic Models, I‘m looking for my first aerobatic Rc Jet. At the moment I fly the Freewing Avanti. Now I want to make a step forward. Which one would you recommend? Carf Rebel Classic, Tomahawk Futura 1.9m, Sebart Avanti XS. Or do you recommend for beginning one size smaller? (Rebel Hot, Mini Avanti). Thank you!
best wishes,
Johannes
Old 04-03-2022, 06:27 PM
  #491
Desertlakesflying
My Feedback: (28)
Originally Posted by DieDuenneSuppe
Hey guys, after flying for many years 3D aerobatic Models, Im looking for my first aerobatic Rc Jet. At the moment I fly the Freewing Avanti. Now I want to make a step forward. Which one would you recommend? Carf Rebel Classic, Tomahawk Futura 1.9m, Sebart Avanti XS. Or do you recommend for beginning one size smaller? (Rebel Hot, Mini Avanti). Thank you!
best wishes,
Johannes
Smaller goes away faster. The 2M Rebel would be my recommendation.
Old 04-04-2022, 05:05 AM
  #492
jvaliensi
Hi,
If you expect aerobatics (from what I've seen) go with the Max or Pro versions. The Hot and 2m tend to fly faster.
Old 04-04-2022, 11:21 AM
  #493
DieDuenneSuppe
Thank you for your answer! Unfortunately, Rebel Max and Pro are to big and expansive.. what makes the Rebel better than the other mentioned Jets?
Old 04-04-2022, 11:24 AM
  #494
Dave Wilshere
best wishes,
Johannes
Rebel 2m will suit you fine. It does not have to be flown fast, it’s now the go to sports jet in my local grass club. Lots of fairly new to jet guys have bought them after seeing other members getting on fine.
This was Steve’s first jet flight landing…ever
DenisFerrari (04-04-2022)
Old 04-04-2022, 11:25 AM
  #495
smcharg
smcharg's Avatar
Weight | manufacturing consistency | customer support (at least in the US and Europe) | Quality | and it just flies amazing
I challenge you to find someone who says that any of the Rebels don't fly good. I'm not saying that people don't have challenges but, once it's in the air, there is no question.
Old 04-04-2022, 12:42 PM
  #496
Dansy
My Feedback: (53)
Dansy's Avatar
best wishes,
Johannes
Out of the one you listed…the Rebel hands down….and pretty easy to build as well, if in the USA give the Rep’s a message they may have one in the Cali already…
Old 04-04-2022, 01:12 PM
  #497
Agrav8ed
best wishes,
Johannes
I have a Rebel and I love the way it flies. I had to add a former to mine to eliminate some flex and acoustic resonance, but it feels great in the air and it go b*lls to the wall but it can land sooooo slooowww. Definitely a great plane. With that being said however, what response did you think you would get when you ask that question on a Rebel forum?
Tone
chevronflyer (04-05-2022)
Old 04-08-2022, 08:17 AM
  #498
N4S
I am planning to add smoke add have a 750 CC tank that fits right behind the spar. It does get in the way of the wing bolt as bolts go in from the fues to the wings. I was thinking to either put quick fitting/push to connect fittings on the oil lines or leave enough slack in the lines so I can move the tank out, install the bolts, put the tank back and reverse the process when I am done flying.
I saw a post on CMJets with 3L fuel and 1L smoke but I can't find it on his website and also, I prefer to keep the 4L tank for longer flight time. Thoughts?
Old 04-08-2022, 09:39 AM
  #499
Len Todd
In one of my planes, I had a similar interference with the wing bolts and smoke tank. I dumped the OEM's thumb screw type bolt and went to socket head bolts with washers glued on. Then I picked up a tiny ratchet wrench similar to this:
MulWark 20pc 1/4 Ultra Low Profile Mini Ratchet Wrench Close Quarters Screwdriver Set with High Torque - Right Angle EDC Tool with 90 Degree Mini Offset Reversible Drive Handle & Multi Hex Bits Set - - Amazon.com MulWark 20pc 1/4 Ultra Low Profile Mini Ratchet Wrench Close Quarters Screwdriver Set with High Torque - Right Angle EDC Tool with 90 Degree Mini Offset Reversible Drive Handle & Multi Hex Bits Set - - Amazon.com
But, when thinking about using smoke, below is a bit of caution from a past smoke user and CD:
IMHO, .. my experience has proven to me that unless your are an experienced "show performer" or a pro, smoke is a PITA, expensive and has a high degree of potential for an unnecessary mess to deal with. It frequently gets in the plane and that makes for a unsettling mess for pilots. Frequently, testing the system and filling smoke tanks screw up the asphalt and turf in the startup areas. Wait till the club, airport manager or a CD comes to you and tells you to clean up your mess. Or the event gets the boot from a borrowed or leased site because the event ruins the site's asphalt. Talk about being embarrassed! Or the smoke fluid dribbles out on your trailer floor or back inside the plane. Smoke is messy period! I have pilots who use drip pans when their planes are sitting on Pit Row. I have seen several planes internally flooded with smoke fluid. I have seen huge puddles from over-filling smoke tanks. I have even seen one pilot fill his fuel tank with smoke fluid. What a mess that turned out to be.
From a building perspective, how are you going to properly fasten a movable tank so that it does not flop around as you fly? It will be heavy and once the smoke fluid starts sloshing around, it can be a challenge to keep it removable and still fixed during flight. I tried smoke several times. For me, it turned out to be just another PITA. And then, when some less than courteous pilot with a really good smoke system cuts in front of you with smoke on while you are on final, @#$#%. Believe me there are a lot of these guys out there!
IMO as a CD for over 50 jet rallies and in the past a smoke user, ... Unless you are a "show performer" or a pro, smoke is just an expensive PITA. Also, many pilots are not skilled enough to avoid the messes or conflicts in the airspace when using smoke. After several years of my personal playing with it and watching others deal with it, I gave up on it.
Just food for thought! But to each his own. Have fun with it. But keep an eye/focused on the plane, vs. the smoke, when using it!
Old 04-08-2022, 04:46 PM
  #500
Desertlakesflying
My Feedback: (28)
You can put one of these on each side of the fuel tank for 48oz of smoke. Didn't even have to use anything to secure them. The tank holds them just right.
Wasn't going to fight the wing bolts. Also think CmJets makes a split tank now, their regular Rebel smoke tank wont work.
https://www.towerhobbies.com/product...oz/DUB424.html
