Reload this Page >
Juniaer K45TP Tucano from Brazil?
Old 01-24-2021, 11:44 AM
  #126
Didier
Originally Posted by Aquilon View Post
Didier,
What size is your 3 blades' propeller ? 20x14 ? And what's about ground clearance ?
I assume diameter 22 is too much.. You confirm ?
I need to select the prop for my Wren44TP...
Thanks.
Stéphane
Hey Stéphane.
I have a JC 20x14 3 blade wooden prop. I also have a Ramoser 20x14 3 blade. There is enough clearance for a 22 if you only from pavement. I fly mainly from grass, so I was afraid for a prop strike in grass with a 22. A lot of video’s from the Tucano are with the JC 20x14 3 blade. Based on the video’s (mine is not ready yet and weather is terrible) it gives such great performance and real Turboprop sound. 😃😃😃
The following 2 users liked this post by Didier:
airspeed917 (02-16-2021), Neil Guildford (01-24-2021)
Old 01-24-2021, 02:27 PM
  #127
Dansy
My Feedback: (53)
Dansy's Avatar
My 45TP run well on a Biela 22x12 Turbo prop .....not on this plane...
Old 02-16-2021, 06:49 PM
  #128
airspeed917
Default Navy T6-B
Just waiting for the K45TP to arrive so I can finish up my Tucano. Had it painted in the US Navy T6-B scheme fully weathered. Totally worth the wait...
Old 02-16-2021, 10:23 PM
  #129
DUCMOZ
Hi all, I don’t know what you think but I just installed the canopy and what a pain doing the glass from outside it is. It probably took me 3 times of normal time it takes to trim and install it and I am still not 100% happy with it. I totally understand modifying the molds is a lot of work but my suggestion is to change so the canopy can get glued from inside the frame like all jets. That would help to make the install easier and a lot cleaner.
thanks
Behzad
Old 02-17-2021, 04:46 AM
  #130
didiwatt
My Feedback: (38)
Behead,
I am surprised at your comment. Mine was pre-trimmed. I did not have to do anything but run a bead of canopy glue, lay the canopy on and tape it down. I was so impressed, I wrote the factory and complimented them.. Wonder why yours was not the same.
Paul
Old 02-17-2021, 04:59 AM
  #131
Didier
My canopy was trimmed as well perfectly and I did not find it hard to glue but, the edge is very small, so there is not a lot of “glueing area”. I think it is better to glue the clear canopy from the inside as well.
Old 02-17-2021, 05:00 AM
  #132
Didier
Looks awesome!!
Old 02-17-2021, 05:08 AM
  #133
Didier
Mine is ready to fly.
I installed the smoke tank already but no smoke pump and connections yet.
Waiting for better weather to come.
Neil Guildford (02-17-2021)
Old 02-17-2021, 07:44 AM
  #134
DUCMOZ
Originally Posted by didiwatt View Post
Behead,
Paul
hi Paul, I had a few issues. One the canopy was trimmed short of course as per their great service, they sent me a replacement (many thanks) Then the frame had fitting issues. That got fixed with some heat and massage! But it is not perfect and it still has uneven gaps in various places. Then there is uneven area for gluing the canopy. In some areas there are slight indentations / uneven area. So if I cut the canopy in straight line, I would have anything between 3.5mm to 2mm glue area which to me looked not so good. The last issue is that the angle of the canopy on the front does not match the angle of the glue area. So basically you have to try to fill that area with glue to get a bound. Otherwise they would not be mating surfaces.
I personally hate to write stuff like this as this is a hobby and we have to have knowledge and know how to overcome build issues. But these guys are awesome so I thought to mention what I thought. To clarify, this is not complaint but is just a suggestion
thanks
Behzad
Old 02-17-2021, 07:46 AM
  #135
Aquilon
Aquilon's Avatar
Didier,
Don't forget the additionnal lead from CB200 to CORTEX Pro Pin4...
Stéphane
  #136
DUCMOZ
Didier, nice install. Good luck with the maiden .
Old 02-17-2021, 08:04 AM
  #137
Didier
Didier,
Stéphane
Haha. If you zoom in my picture you will see 😉
Old 02-17-2021, 08:05 AM
  #138
Didier
Thank you 😃
Old 02-17-2021, 08:49 AM
  #139
Aquilon
Aquilon's Avatar
Yes, you are right...
But, what's about Output 5 ? Look's like only Output 6 is connected to the CB200... Could you explain me ?
Stéphane
Old 02-17-2021, 11:32 PM
  #140
Didier
Stéphane
Hello Stéphane.
Output 5 and 6 of the Cortex pro are mirrored signals of each other. (6 only seems to be bidirectional). So to put port 5 to RX2 doesnt make much sense unless your connection 6 to RX1 has a bad connection. Check the thread of the Cortex Pro. A lot of good stuff is written on that thread.
Bavarian Demon Cortex PRO is here!!
Old 02-18-2021, 06:37 AM
  #141
Aquilon
Aquilon's Avatar
Didier,
The goal for me is to have connection redundancy from CORTEX/A&B to CB200/Rx1&Rx2.
As I understand, your Primary receiver is connected to CORTEX/B, and Secondary receiver is both connected to CORTEX/A and CB200/Rx2 ?
Stéphane
Old 02-18-2021, 08:52 AM
  #142
Didier
Het Stéphane. I send you a pm
Old 02-25-2021, 08:51 AM
  #143
Juniaer Modelismo
Sir. Behzad
Thank you very much for the suggestion. We are already fixing this project in this area. The transparent part will be fixed inside the support in the new models. It will soon be this way.
Any suggestions are very welcome and extremely valuable. This helps us a lot in developing even better products. We just have to thank you.
Sincerely,
Elton Uzai
Old 02-25-2021, 09:25 AM
  #144
DUCMOZ
Hi Elton
Thank you for the action and I am sure it would help to speed the assembly process in the future. Needless to say, we love this plane and your work.
Behzad
Old 02-25-2021, 10:37 PM
  #145
ravill
ravill's Avatar
More pics please. Like whole airplane pics please.
Old 03-15-2021, 04:15 PM
  #146
airspeed917
Default Brakes
Is anyone having problems with the brakes on the Scale gear? When I apply the brakes I get air blowing out of the rim and they don't grab. I tried removing the wheel and lubricating the oring a little with silicone but it still leaks.
Any suggestions?........
Old Today, 11:16 AM
  #147
Neil Guildford
A great afternoon out with my Tucano. My timer is still set to 4mins with little fuel remaining whilst I calibrate the telemetry.
Old Today, 02:24 PM
  #148
Neil Guildford
Default Video
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
