Comparison Time
I watched a video of Martin Pickering setting up a jet with that Core. Talk about simple!
I've been a Spektrum user since the dx7 without issue. Up to and including there dx18, I could always figure out how to program what I wanted, albeit, not always intuitive. Then I bought an ix12. I think it was so simple to program that I was intimidated by it! At first, I was setting models up with my dx18 and just transferring them to the ix12. Then I ran into some dx18/ix12 compatability issues and was 'forced' to learn the ix12. It only took one model to realize how simple it was! But the android bugs and slow operating system are already pretty annoying.
From what I'm seeing, that powerbox core is on another level. Heard good about the Jeti, too, but not familiar with it.
If you haven't watched this video, I suggest it. Good info about the basic functionality and how it's made programming things so simple:
I couldn't agree more - Powerbox Core gets my vote. In fact, my existing investment in Futaba receivers is what is "currently" preventing me from moving.
Note to PB - any chance you could add some level of compatibility between legacy Futaba Receivers and the core? That would make the transition very easy.
One of the nice things about the Core is that its ground up. They weren't beholden to any backwards compatibility.
26 full, proportional channels that run at full speed and full resolution plus telemetry that has as good or better range than the radio. No multiplexing of channels, no any channel over a certain number with lower resolution or speed etc.
The transmitter feel is like a fine automobile. The sticks and sliders use hall effect pickups and everything is nicely machined.
My customers were obsessed with the cost of changing-I just explained that anything you were flying stayed with that system, presuming it was reliable, new models were set up in the Core radio. Over time the conversion is complete and other than the cost was spread over time. I have four radio systems in use over my model fleet and although occasionally it’s a pain having several Tx’s at a meeting...at least I did not need to charge a Tx as spread over the fleet they all got some use only.
i have people who have converted from JR, Jeti and Futaba.
Core voice is coming in the Xmas update for those obsessed with gizmo
I switched from Spectrum to Jeti and now to Core. My move to Core was not about what it can do today but much more about what it will do in the medium term and how easy it will be to do it!
Bob
Bob
Short term purchase, I would say Jeti. They have had more time to develop a larger ecosystem of hardware and software
Longer term, PowerBox. They simply need more time to develop software features and add hardware accessories
I started with Kraft in the 70’s, switched to Futaba PCM single and dual stick in the 80’s and aboutb4 years ago bought 2 Jeti Tx (DC16 and DC24 and too many Rx, ESC and telemetry items to count!)
I am confident my next purchase will be Powerbox Core... I think it’s a better long term investment and a better hardware platform.
I like your take on it. My ix12 will wear out its welcome in short order with all its bugs. I'm at the point, "do I be a Guinea pig with the ix20, or move on?"
Powerbox core is quite the investment, but if it turns out to be just that, an investment, it's completely worth it.
I am still using JR 12X but a change in near future is unavoidable. I have great access to some one to guide me through Futaba programming but no one I know uses Core. If you guys have used Core, do you think it would be better for me to go the Futaba route or the Core?
thanks
Behzad
thanks
Behzad
Behzad
You would find going Core much easier than learning Futaba’s quirky programming that even most long term users struggle with. I think Futaba proved with the face lift 18MZ (32) that they are left further behind. I had a few guys go Core that I expected to struggle and be constantly contacting me, they were like you isolated away where no one around them used high end radios. They got on fine!! I have had other guys who I expected to have no issues contacting me...but I realised they just couldn’t be bothered to find out how to set something out as the info was on PB’s expert forum.
I generally find myself once you understand the basics of how the Tx is programmed (swiping left or right-up and down, double tapping or holding still your finger on the screen) I find most things without research.
Dave
Dave
thanks
Behzad
thanks
Behzad
thanks
Behzad
thanks
Behzad
I've recently converted to Core and I'm someone who has come late in life to large scale RC. Programming of Tx and power distribution systems does not therefore sit naturally to my way of thinking. I've recently changed from Jeti to Core. The Jeti is brilliant in all respect except for it's complexity in use. I accept that that may just be me but, for me a fact of life. The Core I have found to be simplicity itself. It is largely intuitive. The functionality currently available is more than enough for complex aircraft. It's what is coming that excites me. Yes these new development will add yet greater functionality but they will also make things even simpler and will allow much more to be done directly from the Tx.
Bob
thanks
Behzad
thanks
Behzad
https://powerbox-americas.com/blogs/want-to-know-how?
My Feedback: (24)
Early observations but keep in mind that these are just my opinions so far. I am still in programming mode and have only flown the Jeti and of course many flights on the Spectrum. I did not buy the new ix20 because I had an ix12 which I didn’t care for and I gave it away.
Transmitter Feel - Honestly I like them all but I will give the nod to the Jeti. I like the heaviness of the transmitter. So for now it is Jeti, then Core, then Spectrum
TX sticks - I like my throttle stick to have the indentions and be firm. I couldn’t get the core as tight as I wanted, even though the screws are all the way down. Ranking - Jeti, Spectrum, Core.
Stick Trims - it is a tie between Core and Spectrum. I hate the Jeti trim tabs and before you ask I have not tried the auto trim feature. Ranking Core, Spectrum, Jeti
Software/Program/Features - keep in mind I am still learning these so this may change as I set up more planes, especially my larger scale jets. I find the Core much easier than the Jeti. My early, very early, ranking - Core, Spectrum, Jeti.
I am impressed with both the Jeti and the Core. I don’t think you could go wrong with either one. I was planning to sell one of them but who knows I may keep both.
Please keep in mind that I am not sponsored and I am just an average modeler who has been flying since 1976. These opinions are clearly just my observations and may change as I start flying these radios.
Thanks for reading!
Thanks for reading!
My Feedback: (7)
I was really considering the CORE until I started looking at availability of mid sized receivers. It’s 9 channels or smaller or the larger Powerbox receivers. I, like many in the jet field, have a smaller jet and space within the cockpit is limited. I finally decided to go with the ix20 since the PowerSafe receivers have served me well for years. So far, I’m very impressed with it. (Coming from a DX20).
Add on the CORE “NASCAR commercials“ in these threads as mentioned above and all over FB are getting old. We all know it’s a great radio, no reason for shoving it down our throats.
Thanks for reading!
Thanks for reading!
My Feedback: (24)
More thoughts:
Transmitter weights
Core 2# 11oz
Spectrum 2# 8oz
Jeti 3#
the Jeti actually feels more heavy than the actual difference.
Screens - both Jeti and Core screens are great, Core takes the longest to boot up.
I had to change the mode on all three and they were all three very easy to change. No issues.
I did have to buy additional switches for the Jeti, the other two required no changes for my style.
Transmitter weights
Core 2# 11oz
Spectrum 2# 8oz
Jeti 3#
Have you taken your Jeti out into a bright day?
The 9ch Rx will do 10 channels. I would guess a PowerExpander 15-18ch and PB Rx would be smaller and lighter than the Powersafe Rx’s I’ve seen.
thanks
Behzad
thanks
Behzad
