Swiwin Turbines
#101
I use a Futaba 16SZ and set the gear ratio to 1.2
I'm not sure if the "MZ" telemetry programming is different than the "SZ", so crosscheck your RPM between the GSU and your transmitter to verify they're saying the same thing.
Sean
P.S. Looking at your setup, I don't think you need the ECU PPM to Rx Ch3 cable for throttle. I run mine from ECU Telemetry to Rx SBus2 only for throttle...just ensure the GSU/ECU throttle setting is set for Ch3. Maybe the tech experts here can comment if the way you have it establishes throttle redundancy.
Sean
#102
Something else to look at - page 13 of the CRX Swiwin Manual shows these two connections being made from the receiver to the ECU with the throttle connected to PPM. Now, CRX illustration is for a Spektrum Receiver but I would think Futaba would be the same?
#103
Sean
#104
Sean - I went back and watched both the Bad Boyz RC and Thomas Chiang videos and you are right. Both only use two data line connections, not three. They use the SBUS2 and do not connect the throttle to channel 3 directly on the receiver. I removed my third data line between channel 3 on the receiver and PPM on the ECU and it works just the same. So I am not sure why the CRX manual shows two data lines coming from the receiver to the ECU and one being from throttle to PPM. Chaing's video is much older and apparently there is no "Telemetry" plug in named on the ECU. He refers to Data Bus instead. The Bad Boyz video is much more recent and they do refer to a "Telemetry" assignment on the ECU. So for now, I have removed the third throttle line. I would still like to hear from a tech expert why they both work and which one is the safe connection for flight. But, thanks for bringing this to my attention as I am here to learn!
#105
And actually, in my last 4 flights, I installed a hub so I can run GPS as well. So my configuration is Rx SBUS2, to hub, then ECU Telemetry (with throttle) and GPS Sensor plugged into the hub. Thus if anyone sees a problem with this, please chime in.
Sean
#107
I'm still learning too. I've got around 14 flights on my plane with a SW80 and R7014SB using the single Rx SBUS2 to ECU Telemetry connection carrying the throttle and telemetry data...so far no issues...but I too would like to verify that it is still safe to fly in that configuration.
Sean
Sean
#108
Sean
Skunkwrks (02-13-2021)
#111
This was a fun video to put together! It's a long one but there is lots of info in here.
https://www.youtube.com/watch?v=UXg-5aAfbDY
#112
Vey nice video CM. I am looking to purchase my first turbine and it will be a Swiwin 190B My friend runs this turbine on kero and recently switched to diesel. He thought it had more power using diesel. Any chance you can run your motor on diesel and see if you get an increase. I have seen many post of people claiming they saw an increase, but you have a test stand that would prove it or not. Anyway great review and thanks for taking the time to do your videos.
Canadian Man (02-14-2021)
#113
My Feedback: (15)
Hey RangerPaul,
The Nashville group usually fly at Peeler Park in Madison, Tn. I personally have no experience with the Swiwin turbines, but there is a local flyers who does. I might be able to assist with some of your other questions regarding turbine setup. Send me a PM with you contact information if interested.
#114
Jonathan - Thanks for the video it was very well done. But, it did not really address the question I have regarding connecting the throttle from the receiver to the GSU. I see in your video you have connected your receiver to the PPM port on the GSU and I assume this is your throttle connection. If you were to desire to use the telemetry features I would assume you would connect the SBUS2 port on your receiver to the Telemetry port on the GSU? If that is true, you would have two data lines connecting your receiver to the GSU which is how I set up my test stand. If you look up in the thread there has been a discussion that this may not be the way to do it. Others have a single data line from the SBUS2 port of their receiver to the Telemetry port on the GSU and do not connect a throttle line from their receiver to the PPM port on the GSU. The question we have been discussing is which is actually the correct safe way to connect the throttle to the GSU? Can you help us out here?
Method 1. Connected like I did in the video. PPM port connected to throttle channel on receiver. No telemetry.
Method 2. Connected PPM port to throttle on Rec and Telemetry on receiver connected to Telemetry port on GSU. I tried this. I run JR DMSS Protocol so I didn't get any telemetry data.
Method 3. I didn't try connected this to my receiver as an SBUS/Xbus System as I figured it wouldn't work as JR protocol is Xbus and Sbus is mentioned. If using the Bus setup works and you get 1. control and 2. telemetry data than should work fine.
Probably not helpful at all but.....
#115
#116
While I haven't played around with it specifically here are my thoughts on it.
#117
My Feedback: (46)
Great vid CM, I would also be interested in a comparison of Kero and Diesel fuels and the actual difference in power between the two. We know the theoretical differences but it would be nice to see the actual numbers. Also if you could re-do the learn RC function between running the two fuels.
I'm just about to pull the trigger on a Swiwin for my next project, also thinking about making the switch to Kero from Diesel when I do.
#119
My view is with using Kero on this turbine, if you have access to cheap Kero or your not a back to back flier use Kero. If you like flying 5+ times when your at the field diesel is the way to go, I was resistant on making the switch from kero to diesel but I am glad I did and so is my wallet. I did notice a slight increase in thrust switching to diesel. Using commercial heavy duty black bags (Homedepot) to keep my 5Gal can when it is inside my SUV without any smell works great, a tip from Yeahbaby, (Buck)
Also for either fuel I used Kingtech oil.
#120
My Feedback: (46)
#121
Telemetry connection will depend on your RX setup, i.e., Spectrum, Jeti, Futaba or other. The throttle is via the PPM port. GSU to GSU port. Telemetry is via telemetry port.
If you have questions, feel free to reach out to us.
SwiwinUSA.com
CRX Turbines
Andy Fioretti
SwiwinUSA.com
CRX Turbines
Andy Fioretti
Skunkwrks (02-14-2021)
#122
Found this on Youtube about testing different types of fuel in our engines, can answer some questions about fuel types and energy.
#123
My Feedback: (46)
https://www.youtube.com/watch?v=SIfWCWZdfuc&t=4s
#124
SwiwinUSA.com
CRX Turbines
Andy Fioretti
SwiwinUSA.com
CRX Turbines
Andy Fioretti
#125
