Reload this Page >
Pilot J10
Pilot J10
Old 12-01-2020, 01:49 PM
naxete
Originally Posted by AEROSHELDON View Post
Thanks. How did you guys drain grease?
Just take the spring out clean it with a rag and that is. I added a bit of light grease to reduce friction. I tested dropping it from around 2-3" and worked great.
Old 12-01-2020, 02:56 PM
GULDUKAT
I wasted a can of brake cleaner and a pair of nitrile gloves on it. I found that to be the easiest.
Took the spring out - sprayed brake parts cleaner on it till all the grease disappeared. Soaked a rag in brake parts cleaner and cleaned the springs wells. - 5 mins and it was all gone. Then added some light grease and assembled it back...
If you see the video of the VSTOL I posted - that had a harrier landing of sorts all day long - 8 or so flight that day.
Old 12-01-2020, 03:52 PM
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Thanks guys. I fly exclusively from hard surfaces so it's good to know how to soften it up a little if needed
Old 01-15-2021, 03:01 PM
flyloose
flyloose's Avatar
Anyone care to post some internal install pics of their J-10? Nice to see where you all decided to place your equipment in terms of CG...Got mine ordered and considering a slightly heavier KT235G4
Old 01-16-2021, 02:15 AM
GULDUKAT
We have 2 of these at our field - with KT 210 G2 (appx. 1750g + 150g in cables) and Swiwin 220 (appx 1750g + 50g in cables)
Images for setup are similar to the ones on:
https://pilot-rc.com/j10-b-2-95m-116/
https://www.chiefaircraft.com/pdf/J10-manual.pdf
I thought about putting the 235 - but the K235 G4 (2100g + 50g) an additional 250g compared to my K210 G2 . To offset - I will have to add 250g to the nose. The performance with the K210 is great and with the 220 much better. The stock tank is 4L - as such you have to possible add another tank for the 235 as well.
Mods I made to save battery tray weight:
Moved stock 250ml UAT to forward fuselage (just a little front of the battery tray)
Fuel pump is under battery tray
Smoke pump is also under battery tray
Batteries used: 1X 3S Hobbyking LIFE 2200mah, 2X 2S LIPO 2200mah Pulse
Weight on front nose wheel - appx 900g (no lead weights anywhere).
Old 01-16-2021, 09:43 AM
  #31
flyloose
flyloose's Avatar
Thanks for the info. So based on the CG you're flying with, a KT235 would require added ballast (or bigger batteries etc) to balance.Good to know
Is there a noticeable improvement on punch out between the SW220 vs the KT210G2?
Old 01-16-2021, 12:31 PM
  #32
GULDUKAT
the 220 is definately better! More POWA! 🤣
I have about 100 or so flights with my 210. If I were to do it again I would put a 220 in it. It just feels a lot more locked in and everything is a little bit more crisp. Not to mention that the installation is so much easier with just a single cable going to the turbine. My 210 G2 has almost 150g in cables! Ugg!
Old 01-16-2021, 07:32 PM
  #33
flyloose
flyloose's Avatar
Thanks again for the info.....👍
Old 02-14-2021, 10:08 AM
  #34
flyloose
flyloose's Avatar
A few pics of the green scheme....bit of a lime feel going on 🙂
Old 02-14-2021, 04:02 PM
  #35
airborn900
My Feedback: (25)
This plane is on my list, I love the green. Not sure exactly when I will get to it, but it is definitely one I want to try eventually.
Old 02-15-2021, 01:46 AM
  #36
GULDUKAT
Default Pilot J10 - gear grease
I suggest you check the gear for excessive sticky grease/lube. Mine had too much sticky grease/lube. I removed all of it for the spring to have any effect.
Old 02-15-2021, 02:37 AM
  #37
flyloose
flyloose's Avatar
You bet....thanks
I opened up the scissors on one of the struts and took a look inside there. I’ll be cleaning all that up and adding some light oil once the thick grease is removed. Gives me something to do on it while I wait for servos and components to arrive
Old 02-19-2021, 01:20 AM
  #38
GULDUKAT
Default Almost ready for maiden - this Sunday (weather permitting)
PilotRC J10 Red 112"
Swiwin SW 220
Bluebird H51B Helical Gear Servos X 5
Cortex Pro
3s lipo 2200mah
2s lipo 2X 4400mah
Full uat - 250ml
No smoke fluid - empty 1.5L Smoke tank and PilotRC Smoke pump
No fuel - Empty larger 5L tank for possible 8-10min flights
Right gear 5704
Nose gear 962
Left gear 5646
12312g = 27.14lbs dry (full UAT)
Old 03-01-2021, 10:11 AM
  #39
Desert Fox 1
Cheers!
Desert Fox 1
Old 03-01-2021, 10:39 AM
  #40
flyloose
flyloose's Avatar
Great maiden on your second J-10....performance looks incredible with that 220....congrats 👍
Old 03-03-2021, 01:11 AM
  #41
GULDUKAT
Thanks. Yes - I reduced nose wheel weight to 1100g. The extra power from the SW220 and the lighter nose has made a world of difference!
Old 03-03-2021, 03:55 PM
  #42
Desert Fox 1
Cheers!
Desert Fox 1
Old 03-03-2021, 09:30 PM
  #43
flyloose
flyloose's Avatar
Now that was sweet 👍
Old 03-11-2021, 01:28 PM
  #44
flyloose
flyloose's Avatar
Install is coming along quite well. Iíll need to get my turbine ordered soon here now. Hereís a quick video of the thrust vector install....I used Savox 2291ís for their speed 0.05...
Old 04-01-2021, 05:25 AM
  #45
Desert Fox 1
Cheers!
Desert Fox 1
Old 04-01-2021, 06:46 AM
  #46
flyloose
flyloose's Avatar
Awesome flight....great videos btw desert fox 👍
Hey do you leave your TV on the entire flight? Did you end up adjusting your throttle curve or is it still hovering at half stick? I just got my 240 the other day, but Iím half way around the world in a hotel room with my work 🤪.....Iíll get installing when I get home
Old 04-01-2021, 11:04 AM
  #47
GULDUKAT
I have 2 modes - one with TV and 1 without.
For pattern flying - I turn the TV off but I do most of the flying and land with it being on.
I have not adjusted my curve for the throttle.
Old 04-01-2021, 11:06 AM
  #48
flyloose
flyloose's Avatar
Thanks 👍
Old 08-09-2021, 10:56 AM
  #49
Desert Fox 1
Cheers!
Desert Fox 1
Old 08-09-2021, 12:33 PM
  #50
flyloose
flyloose's Avatar
Awesome 👍
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
