Me163 Air-Classics 1/4
I found this very well done kit from Air-Classics, German small manufacturer, and started the build recently which should be relatively quick to the simplicity of the model. Scale 1/4, meant to support up to 14 Kgs thrust turbojet and using scale flaps, speed-brakes. I’m in direct contact with Andy from Air-Classics who is suppose to send me throw values (I don’t want to discover them by myself, not much room for mistakes here).
Anyone else building this fast egg ?
My Feedback: (48)
Initially my Me-163 was 11 - 12# dry. I didn't like his flimsey wings, so I built new ones, fully sheeted with flaps, added a smoke system and nose weight to balance. After all that it was about 15# dry.
You can see my build photos at Anyone have a Turbine ME-163 on this site? I got some questions
Joe
Joe
My Feedback: (44)
6. For RC fixed wing aircraft: With the exception of hand-launched aircraft which have no undercarriage and with a flight weight under 7.5 pounds wet, the model shall be able to come to a controlled stop on command with the engine at idle on a level hard surface.
If you search that entire document there is no mention of "brakes", only that the model must come to a commanded stop at idle, how that is achieved is totally up to the modler.
This requirement is also exempt for aircraft under 7.5 Lbs wet.
Item 10 exempts the rudder for aircraft under 7.5 Lbs wet, unfortunately this one most likely would not meet that exemption.
10. With the exception of hand-launched aircraft, with a flight weight under 7.5 pounds wet, controllable rudders are required on all RC aircraft.
Well if we're picking hairs rule 6 says aircraft with no undercarriage AND under 7.5 lbs wet, not OR. So by weighing more than 7.5 lbs, it is not exempt regardless of the undercarriage situation. But sliding on its belly at idle it's not going far and is going to come to a stop, so while not exempt I would argue that it is still within the regs.
Air-Classics Me163 1/4 scale ready for maiden
Me163 ready for maiden, jut needs good weather and guts ...
Total weight empty is 12.3 Kgs including "landing" gear which weight 400 grs
Engine Jetcat 120.
Radio Jeti with CB220, RSAT 3 + 900 Mhz
Ditex Servos
Here is the recommended throw by Air-Classics, they sound like a lot of throws, especially on the airbrakes, 75 degrees, while the real one was more 45 degrees
If you have a similar sized one, appreciate if you can share yours.Elevator all fold + 35mm-35mm 30% expo
Aileron only outside + 30mm-30mm 35% expo
Speed brake Mix 75-80 degrees and elevator 10% to positive
Engine Jetcat 120.
Ditex Servos
Does anyone have a link?
The Air Classics page I found does not show this model
Air Classics - Startseite
Is this the wrong company?
