Repair Technique Suggestions...
I had a minor mishap yesterday. This is a canard from my SAB AVIO Lizard. Spares are not available yet, so I need to repair. I'd like to get some suggestions for repair methods.
Thank you!
Thank you!
My Feedback: (28)
I would get some 1/16 balsa and cut it to have the grain parallel to the leading edge. Hysol the balsa into one side of the stab to make a tongue as far as you can get it in both pieces. Do this on both top and bottom. When one side is cured apply hysol to the other side and the edges of the Airex. Push them together and secure with tape. Make sure the leading/trailing edges of the stab are straight.
Will use gorilla glue ( spray a bit with water)
make sure everything is strait and tape. When dry sand and fill any whole and repaint.
will use Epoxy if the rod for the canard is damaged for sure..so many way to fix
