Reload this Page >
Who painted this jet? CARF Flash F86 scheme
Old 04-07-2020, 02:20 PM
txshan130
My Feedback: (113)
txshan130's Avatar
Default Who painted this jet? CARF Flash F86 scheme
I am about ready to have my flash painted in this scheme, but unfortunately I have no idea where to start with the colors or finding paint similar to this. So I'm wondering if anyone on here painted this jet or knows who did paint it and could help me with identifying the paint codes/colors used? Any help would be appreciated. thanks
Old 04-07-2020, 04:40 PM
airsteve172
Is this plane in your possession or have you seen it in person? The reason I ask is because in some ways it looks suspiciously like iron-on film, but it's hard to tell from the photos.
If this is indeed paint, then it seems to have some unusual attributes. One unusual aspect of the paint is that the finish is exceptionally smooth without any hint of orange peel. This is unusual for two reasons. The first is that such a caliber of paint finish is usually reserved for show models and requires an uncommon level of expertise, but the second reason is in contradiction to the skill and effort of the painter as there are some weird flaws in the midst of otherwise great surface preparation.
In any event, I suggest that you look up your local auto body paint supplier. If you can't find one, ask at a body shop where they get their supplies.
The reason I recommend auto paint is because it is very unlikely to be able to attain that level of finish with paints and materials available for hobby purposes. An auto body suppier can also make up paint in any shade imaginable and if you have a sample they can computer match it exactly! The downside of using auto paint is that you better have some idea of how to select the type of paint (there are several) as well as have familiarity with its application. The only instructions you'll find on a can is mixing ratios for hardener so knowing the techniques for spraying it is up to you.
Old 04-07-2020, 07:43 PM
Auburn02
Old 04-07-2020, 11:39 PM
Dave Wilshere
I think it started like as a Jolly Roger Classic Flash, it’s been damaged and the guy has repainted the top. It looks like a heavy coat and clear.
Old 04-08-2020, 03:05 AM
airsteve172
Originally Posted by Dave Wilshere View Post
I think it started like as a Jolly Roger Classic Flash, itís been damaged and the guy has repainted the top. It looks like a heavy coat and clear.
While I have no idea about the history of this aircraft, it does seem to have the earmarks of a basecoat/clearcoat finish, applied by someone with above average painting skills.
Old 04-08-2020, 04:29 AM
RCFlyerDan
My Feedback: (53)
RCFlyerDan's Avatar
As David has said, whomever owned it before touched up with base coat-clear coat. Unless you know what you are doing or willing to go through the cost of learning. The paint and supplies are expensive. You can use Omni, PPG, Nason or DuPont. Silver as a base coat is extremely difficult to apply and adhesion if applying any color coat over it. It isnít Monokote. Airex canít have Monokote applied over it, because it will melt or warp if gotten too hot. If you are only doing touch up. If you can find a NAPA paint store, NOT part store, NAPA will match up the paint if you take parts to them. Then they will make the paint with clear coat in it and put it in a rattle can. If youíre wanting to paint the whole jet, then it needs sanded all over with wet 1000, sealer applied, then base coat, clear coat. YouTube has a lot of professionals giving lessons to watch their channel.
Hereís my Lightning that I did a total refurbishment sanding down to the fiberglass. My silver is actually two silvers airbrushed over each other for shadowing.
Pilot installed
Maiden day prior to pilot head finished
This was painted in my garage.
Old 04-08-2020, 04:56 AM
RCFlyerDan
My Feedback: (53)
RCFlyerDan's Avatar
Just know that whatever you paint, if you screw it up, simply sand it off and do it again! Itís how you learn! Definitely have a chemical respirator! This stuff is nasty to work with.
Old 04-08-2020, 11:09 AM
ravill
ravill's Avatar
I believe Kenny McSpadden painted that flash. It looks amazing in person!
Old 04-08-2020, 11:10 AM
ravill
ravill's Avatar
I’ll see if I can find his rcu handle.
Old 04-08-2020, 11:52 AM
ravill
ravill's Avatar
His handle is GR7Racer.
Old 04-08-2020, 02:05 PM
Eagle Driver
Eagle Driver's Avatar
Ask Jeremy (LGM Graphics) here on RCU, he can help you with all the info you need.
This Flash looks like a easy paint job ;-)
Here`s my Ultra Lightning ...
Old 04-08-2020, 04:45 PM
RCFlyerDan
My Feedback: (53)
RCFlyerDan's Avatar
Respect😎
Old 04-09-2020, 12:27 PM
txshan130
My Feedback: (113)
txshan130's Avatar
Thank you! I really appreciate it!
And thanks everyone for the help and suggestions! I wont be painting the jet as I have pretty much no painting experience lol. Having it done by a friend with a paint shop.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
