Reload this Page >
Jeti Jeti Wireless & Touch Switches, Servo Protection, Rx Battery Telemetry....
Old 04-08-2020, 07:43 AM
ZB
Default Jeti Jeti Wireless & Touch Switches, Servo Protection, Rx Battery Telemetry....
https://www.espritmodel.com/elite-el...y-systems.aspx
Voltario T30 12V/10A Elite Jeti Telemetry Sensor Current/Voltage/Capacity & RC Power Touch Switch
Voltario T30 combines Touch w/LED (Included), Wireless (R3/RSW) or Mechanical Switch functionality together with telemetry sensor in a single device. Voltario T30 uses advanced technology to reach minimum size and enhanced set of features.
Voltario T30 is designed to turn On/Off the electronics in your model. If you use a dedicated receiver battery, the Voltario can be used to directly replace a mechanical RC switch. Specifically in thin glider fuselages or models equipped with a small BEC circuit, the device will offer great benefits like a small size and receiver battery monitoring. The device remembers its last operating state, and if the battery is accidentally disconnected, the Voltario will automatically boot up again as soon as the battery is connected again. JetiBox Monitor/Programmer can be used for programming and live telemetry data display during bench setup and testing.
Voltario Telemetry Sensor monitors your Rx Battery Voltage (V), Capacity (mAh), and Current (A)
ID:	2266991 Click image for larger version
Old 04-08-2020, 07:44 AM
ZB
Voltario S30 12V/30A Elite Jeti Telemetry Sensor Current/Voltage/Capacity & Servo Overload Protection
Voltario S30 is designed for monitoring power consumption of a single servo. It offers additional possibility to set the overcurrent protection shutdown with telemetry alarm if servo is disconnected. JetiBox Monitor/Programmer can be used for programming and live telemetry data display during bench setup and testing.
Voltario Telemetry Sensor monitors your Servo Voltage (V), Capacity (mAh), and Current (A).
Plug the Voltario S30 between receiver output channel and servo of your choosing. Voltario S30 also works fully autonomously as a programmable fuse (this function has to be configured first). To view the live telemetry data you can link the Voltario S30 with the receiver telemetry port.
- Jeti Duplex & Graupner HoTT telemetry support (Current, Voltage, Used Capacity)
- Optional High Current Shutdown with Power Regeneration
- Programmable Overcurrent Protection (0.1A - 20A)
Shutdown Current – you can specify the maximum allowed current before the Voltario shuts down the load. By default, after reaching the shutdown current, it takes approximately 0.5 seconds before the fuse reacts. But the overcurrent shutdown reacts proportionally faster if the current is higher.
ID:	2266994 Click image for larger version
Old 04-09-2020, 11:55 AM
ZB
Let's see if we can add YouTube video.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
