Jeti LiIon RX batteries
My Feedback: (53)
Charge box are fairly easy to make.....just need a little of planning. My Dual PL8 revolectrix with a bump controller and a 48v power supply from Mean well
And this one is a single PL6 from Revolectrix with Bump controller and a 24v mean well power supply
#31
My Feedback: (54)
bodywerks (07-09-2020)
#34
Zb/Jeti USA
#35
We just added new Sliding Power Switches with incredibly low Standby Current: 0.05mAh (50 uA)
You can use our electronic switches as standard RC or even Ignition/ICU On/Off switch.
Zb/Jeti USA
https://www.espritmodel.com/search.a...ing+mechanical
[img][/img]
[img][/img]
Zb/Jeti USA
[img][/img]
[img][/img]
#36
You can also make your own packs using Panasonic NCR 18650 B 3400mAh 3.7v FLAT TOP Lithium Li-Ion cells for instance and then getting the Li-ion balance boards and they are very simple to wire up.
Regards,
Regards,
#37
10.8v? Are these actually li-ions that MUST be charged to 4.1v peak? What is their c rating? Swiwin turbines require a 3s lipo. They will run on LiFe, but prefer 11+ volts continuous. I'm hoping these ~12C rated 2600A li-ions paralleled up to 5200mah will be able to handle my sw220b in its sleep.
#39
So, I went to pick up my new turbine this weekend and brought my ammeter with me to see what kind of current a battery must endure during start, cool, and full power on an SW220B brushless turbine. I was quite surprised that the max amps I saw was around 5 amps during start-up. Max power was only around 2-2.5 amps, and cooling only around 3.5-4 amps. I'm sure the li-ion will handle this no problem.
#40
My Feedback: (46)
#41
I initially used the Li-Ion charger setting, but noticed that I couldn't get full capacity on a discharge. I was then advised to use the Li-Po charger settings and this allowed a full charge. Internal circuitry in the battery pack protects from overcharge. Charge them like a Li-Po, but without having to balance charge them, or discharge them for storage.
Paul
Paul
#43
Paul
Paul
#44
Jeti are for sure meant to charge using the lipo setting, and the discharge chart for the 2600A cells shows them averaging over 3.5v/cell at like 20 amps continuous.
#45
My Feedback: (46)
can't speak for Fromeco. They are old tech these days. Their 4800-5200 packs were only rated for like 8-10 Amos continuous, and even at that they would drop down to like 6.9 volts.
Did you generate the chart or get it from somewhere?
#46
Received my 3s2p 2600A battery pack from Jeti in the Czech republic. It only weighs 10 ounces, which is light for a 35+lb jet. I also checked amps during all phases of running on this SW220B turbine and the highest amps observed were only 5 amps, and that's only during start-up. Average consumption is only around 2.5 amps. This Li-ion should do the trick nicely!
