Reload this Page >
Looking for help or ideas on how to determine if there is oil in your fuel
Old 08-09-2020, 11:31 AM
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Default Looking for help or ideas on how to determine if there is oil in your fuel
Hi Fellas,
Before we got hit with the pandemic I picked up 2 x 5Gal containers of Jet-A preparing for the season. I added oil to one and made a mental note regarding which of the two had the oil. Well, I did not end up flying this season and was not expecting to take such a break. I am fairly confident which of the two containers has the oil but due to the amount of time I am starting to second-guess myself. The oil I use is Kingtech and it mixes pretty well - so no obvious color difference.
Do you guys have any ideas on how best to test the two to confirm which has the oil? An idea I have is mixing the 10Gals together and adding the corresponding 5Gal's amount of oil to the mix. But I do not have enough containers to do that. I also thought of using a white piece of paper to add a few drops of the fuel. Once it evaporates it should leave an oily residue if mixed with oil. I'm unsure if this will work with Jet-A though, as it may be oilier than gasoline. This is an old motocross trick used with gasoline on 2-stroke motors.
Any help would be appreciated - thank you!
Old 08-09-2020, 12:16 PM
naxete
If you had exactly 5gal on each before adding the oil you should be able to tell the difference by weight / volume?
The following 2 users liked this post by naxete:
Auburn02 (08-10-2020), skunkwurk (08-09-2020)
Old 08-09-2020, 12:19 PM
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Originally Posted by naxete View Post
If you had exactly 5gal on each before adding the fuel you should be able to tell the difference by weight / volume?
What a great idea. It looks like a quart of oil should weigh about 1.83lbs. Let me try that.
Old 08-09-2020, 12:31 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Will the added oil show on a paper filter ?
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
haha - that worked perfectly, thank you so much.
I just weighed both and got 37.5 vs 39lbs. I used a simple bathroom scale which measures to .5 lbs resolution.
Old 08-09-2020, 01:15 PM
Wclays
My Feedback: (85)
I have done the same in the past.(I now mark each can with flags that say mixed) I poured some fuel in a glass jar. (left it in the sun, its 109 today) If there is oil in the fuel, it will not evaporate and the oil will be left.
I tried this with just Jet-A and when it evaporated it was pretty much clean. The mix left a residue. Try it with both of the your fuels and see what is left in each one.
Old 08-09-2020, 01:27 PM
naxete
Great!
Old 08-09-2020, 02:32 PM
causeitflies
causeitflies's Avatar
That was a good solution .
I always put the oil in the jug first. That way when I fill it there is no doubt and always oil in the fuel.
Old 08-09-2020, 04:02 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
I use Amsoil Dominator synthetic racing oil. Its red and so is my fuel.
Old 08-09-2020, 04:46 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
I always put the oil in the jug first and then I get Kerosene from a local bulk plant so swirling the nozzle around while filling the jug helps get it mixed. So If there is a full fuel jug in my shop, it's got oil in it.
yeahbaby (08-10-2020)
Old 08-09-2020, 05:48 PM
flyinfool1
flyinfool1's Avatar
One more vote for never putting fuel in the jug before the oil.
I also add a home made BioBor JF mix that contains a dye to further identify mixed fuel.
Old 08-09-2020, 05:51 PM
sysiek
My Feedback: (176)
sysiek's Avatar
Just add 1 quart of oil and mix all the fuel to big container and back to 5 gallons jugs , problem solved
Old 08-10-2020, 06:10 AM
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Thank you for all of the help and comments, guys. I appreciate it!
Old 08-10-2020, 01:56 PM
JohnMac
JohnMac's Avatar
Just an idea to help in the future. I use those small indicators for Lipo batteries on my Jerry can. When I have emptied the can I click the indicator to red and store it until I am ready to go and get it refilled. Then I add I litre of oil and click the indicator to green. Job done. No more worrying about the fuel mix. I add 19 litres of Kero and I have the correct mix.
John
Old 08-10-2020, 04:56 PM
Desertlakesflying
My Feedback: (28)
I put my oil in my cans as soon as they are empty so I don't ever forget because it's already there
Old 08-10-2020, 07:58 PM
CARS II
My Feedback: (7)
CARS II's Avatar
This.
Old 08-10-2020, 08:02 PM
CARS II
My Feedback: (7)
CARS II's Avatar
And this + a simple strip of yellow painter's tape with this written on it, oil + algaecide added.
Old 08-11-2020, 03:48 PM
ravill
ravill's Avatar
Oil only goes in my jersey modeler. No where else.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
