Treating Kerosene
Treating Kerosene
I picked up some kerosene in an attempt to maiden my on of my jets. Lttle did I know that either the kerosene I bought was contaminated or there was with something in my jug, but the fuel was really cloudy and almost seem like there was abit of slime lying in the bottom when I emptied it. I am assuming there was some sort of fungus present. I have changed kero suppliers but what can I use to treat the fuel that would be safe for our turbine engine?. I saw a couple things for diesel fuel but not sure if it is safe for kerosene or are turbines.
Tone
Tone
My Feedback: (53)
I use this for my diesel. I know other guys use it in kerosene as well
https://www.biobor.com/products/biobor-jf-aviation/
Also I have a question on how to mix this Biobor. If it is 1 ounce per 75 gallons how much are you actually adding to a 5 gallon can?
Tone
My Feedback: (64)
I use it with diesel but am pretty sure that my friends that run kero use it also. I will try to confirm with them today.
The technical data sheet clearly shows kero
https://www.biobor.com/Biobor-Resour...cal%20Data.pdf
I buy it on Amazon. A little goes a long way
https://www.amazon.com/gp/aw/c/ref=mw_dp_buy_crt
Based on the chart you supplied (thank you, very usefull) it shows I should mix around 4ml's per 5 gallons. Dose this sound correct?
Tone
My Feedback: (64)
Probably best to contact the engine manufacturer. I just checked with a friend that burns kero, and he said it is only needed with Diesel.....not kere so not really sure and do not want to mislead you. Biobor does make it strictly for aviation fuel too https://www.skygeek.com/hammonds-bb0...-s-53021a.html
My Feedback: (7)
I have for a few years now, I used the Kero from HD ( no algea, super clean ) then decided to try Diesel, didn't like the smell or the extra smoke then I got my first flame out because the filter on my engine was plugged with clear algea and my gas can had algea in it, switched to red Kero from the pump ( farmers Kero, less tax is the only difference) but since it came from an underground tank I used algaecide ( biobor) that happened almost 3 years ago, still use algaecide in my 5 gl gas can and my 2 gl smoke fluid can ( Diesel/mineral oil ) as of now my gas and smoke cans are algae clean, use double the recomended amount for the first time in a full gas can and let it seat for about a week if possible to kill the algea then use the recommended amount which is just a couple ccs, yes, you only need a tiny bit per 5 gallons, the 16 oz algaecide bottle is good for about 1500 gallons.
I've used the Bibor in my K80 Kero start, K140 propane start, Jetcat P60 propane start, P80 propane start, TJT300 ( 27 lbs thrust ) 20 years old engine build in Australia, I use in the same Kero in all of them, all are and have been running perfectly for years.
Tone
My Feedback: (7)
I believe that as long it is for Diesel it's good to use, I used Bibor at first then I got me a bottle from the gas station where I get my Kero, not Biobor but it's algaecide for Diesel.
You can find Bibor at any West Marine boat store.
Agrav8ed (09-06-2020)
Agrav8ed (09-07-2020)
My Feedback: (41)
Yeah here's another vote for the Biofor JF in Kerosene. I used to use a different brand of biocide but it got too hard to get ahold of. Also, for possibly contaminated fuel there's an outfit calle "Mr Funnel" that has some nifty filters for fuels,
Home
You can buy them at different places including Amazon.
Home
I heard back from Biobor. Apparently the diesel and aviation versions are identical besides the label and biobor works on any hydrocarbon.
Thank you for your inquiry. Biobor JF is suitable for use as a biocide and lubricity improver in any hydrocarbon based fluid including jet fuel, diesel and kerosene. Aviation certified Biobor JF undergoes additional QC checks, specification testing, carries aviation approved labeling and is priced separately from non-aviation Biobor JF. I attached Spec Sheets on Biobor JF for aviation and non-aviation. Please let me know if you have any additional questions.
So that answers the question if the diesel variant is safe to use with kerosene
Tone
Tone
Agrav8ed (09-08-2020)
My Feedback: (18)
Tone
Tone
I found a way to easily mix the biobor.
I got a 16 ounce Bottle like the ones used for 2 cycle oil with the built in measuring cup.
Add 1 fl oz of biobor to 15 fl oz of your jet fuel (Mine is K1 Kero from the gas station underground tank). MIx well
This diluted mixture is 1 fl oz per 5 gal of fuel to end up with the correct dosage.
It is just to hard to try measure out the couple of drops required per 5 gal.
This has been working for me for the last 12 years just fine, Never had algae even when I had to take 3 years off flying.
As for the fuel you have with algae in it, Biobor recommends to double the dosage to kill existing algae, It would give it a couple days and then run it all through a good filter to get the dead algae out .
My Feedback: (18)
Yea I guess I'm lucky too. My local FBO allows me to walk out to the pump truck and they fill my 5gal containers. The Jet-A is always clean and H2o free. It is a pretty busy regional so the truck is constantly on the move. Not sure why I'd prefer to trust what is sitting in the kero tank at the local gas station.
