Fuel leak damage and repair help
So I ran out of daylight yesterday and had to pack up early. I came out to my trailer today and saw that there was fuel on the floor of the trailer. It was also pooled in the bottom of my jet and soaking the wood formers. I am going to pull the tank for inspection. But the biggest problem is the fuel soaked wood. Can anyone tell me what I can use to get the fuel out of the wood and repair it. I would prefer not to replace all the wood formers if possible.
thanks,
Tone
thanks,
Tone
My Feedback: (46)
I’ve used this in the past with good results, you will probably have to do multiple applications but it will get it out.
K2r SPOTLIFTER
K2r SPOTLIFTER
This is why I resin coat all my wood work in ZAP40 before I build...I know that does not help you now, but it’s worth the hour spent at the beginning of a models life.
Dave
Dave
Tone
camss69 (11-06-2020)
My Feedback: (13)
For what it is worth, several years ago I was cleaning up some ducted fan jets which had become saturated on the formers and exposed wood surfaces. When I posted here for suggestions I got several totally less than useful suggestions, more than I expected, which caused me to be careful of seeking advise since. This was one of the helpful and less sarcastic suggestions. ( I didn't like the suggestion I simply toss the plane in the bin for instance ). The only thing that ended up helping in my case were multiple applications of K2R. I still have a part of the last can on my workbench.
Tried acetone, alcohol, baking soda, and several kitty litters and any desiccant I could find. All help a little after multiple applications. The K2R was easiest and most productive. After each application it needs to be scrubbed around a bit, heating didn't do much and I was afraid to get it any hotter for fear of damaging the fiberglass and the epoxy joints. It then needs to be vacuumed out thoroughly before the next application. Letting it sit for a week between applications didn't seem to help either.
Just my experience, FWIW.
John
John
My Feedback: (20)
K2R over and over till its dry. Been using it for decades since the glow days. Then do the epoxy coating mentioned above.
