Reload this Page >
Aviation Design Diamond Assembly!
Old 12-21-2020, 09:08 AM
  #101
Canadian Man
Canadian Man's Avatar
Finished front shot of wing tip light
Front Vertical Opened up. Glue joint sanded down.
Rear vertical opened up. Glue joint not sanded yet.
Old 12-21-2020, 09:10 AM
  #102
Canadian Man
Final product is way better than I expected! The majority of the lens is clear when viewed from the side. the area near the tip glows and is very visible from the side!
Skunkwrks (12-22-2020)
Old 12-27-2020, 07:48 AM
  #103
Canadian Man
Smoke System install in the diamond.
Skunkwrks (12-28-2020)
Old 01-26-2021, 09:57 AM
  #104
sysiek
My Feedback: (176)
sysiek's Avatar
So to everyone who has a hard time to find the servo horns for the aviation design servo plate and the hardware that they supplied with the jest I have custom made servo arms that will fit futaba savox and all the 25t type ones for $8 each, they one hole bigger than needed but they very easy to cut and form to the desired length
please contact me if you need some off those, thanks
Canadian Man (01-26-2021)
Old 01-26-2021, 11:24 AM
  #105
Canadian Man
Thats Awesome! Hard item to find!
Do you find any issues with running the servo output closer to the opening vs flipped around to be further away from the opening?
Obviously you can run a longer servo horn but mainly just wondering if there is any binding anywhere?
Old 01-26-2021, 11:42 AM
  #106
sysiek
My Feedback: (176)
sysiek's Avatar
Actually this is what I always was doing and this is what instructions showed for this type of plate, if you do it the other way I find that the linkage will be limited and will stop at the servo, don’t center the arm just have it on 1:15 o’clock off center this will give you more movement
Old 04-07-2021, 06:28 AM
  #107
Canadian Man
Something a bit different for the maiden!
Old 04-07-2021, 11:21 AM
  #108
mikes68charger
My Feedback: (34)
The Diamond was my favorite jet. Lost it at a show trying to get a higher mph pass than those little bandits, the elevator horns pulled out 15ft over the runway, total loss
Old 04-08-2021, 06:32 AM
  #109
Canadian Man
Ouch! Did you glue in the horns into the surface or was there hard points added?
Old 04-08-2021, 07:15 AM
  #110
scoeroo
My Feedback: (9)
scoeroo's Avatar
Nice maiden -
Old 04-08-2021, 08:32 AM
  #111
mikes68charger
My Feedback: (34)
Glued to surface wish I would of did 2 horns per elevator
Old 04-17-2021, 09:26 PM
  #112
Canadian Man
Flight 3 which happened same day as maiden.
Viper1GJ (04-18-2021)
Old 04-27-2021, 06:52 AM
  #113
Canadian Man
Diamond gets an upgrade! And free light giveaway. Details in the video.
Old 05-04-2021, 01:29 PM
  #114
Canadian Man
Flight 6. Having some more fun with the plane now. This was prior to the upgraded marker light install.
Old 06-09-2021, 08:55 AM
  #115
Canadian Man
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
