Aviation Design Diamond Assembly!
Skunkwrks (12-22-2020)
Skunkwrks (12-28-2020)
#104
My Feedback: (176)
So to everyone who has a hard time to find the servo horns for the aviation design servo plate and the hardware that they supplied with the jest I have custom made servo arms that will fit futaba savox and all the 25t type ones for $8 each, they one hole bigger than needed but they very easy to cut and form to the desired length
please contact me if you need some off those, thanks
Canadian Man (01-26-2021)
#105
Thats Awesome! Hard item to find!
Do you find any issues with running the servo output closer to the opening vs flipped around to be further away from the opening?
Obviously you can run a longer servo horn but mainly just wondering if there is any binding anywhere?
#106
My Feedback: (176)
Actually this is what I always was doing and this is what instructions showed for this type of plate, if you do it the other way I find that the linkage will be limited and will stop at the servo, don’t center the arm just have it on 1:15 o’clock off center this will give you more movement
Viper1GJ (04-18-2021)
