Reload this Page >
Yellow Aircraft F18 Twin (one engine) thrust pipe
Old 01-25-2021, 08:03 AM
loukos
Default Yellow Aircraft F18 Twin (one engine) thrust pipe
Hey guys,
Building a YA F18 twin but with a single turbine. Turbine of choice is either a Kingtech 210 G4 or a jets munt 210.
I have the Tamjets pipe, with an inlet diameter of 3.5 inches, if i recall this pipe was designed for 160-180, but i cannot find an accurate reference.
Anyone try the Jettech USA thrust pipe, seems more substantial than the Tam pipe?
Regards
Loukis
Old 01-25-2021, 08:46 AM
kevinthoele
I flew several Yellow Twins and the Tam pipe was what I used in single engines. I flew them on both twins and singles
Old 01-25-2021, 08:48 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Is Gary making Y pipes now?
loukos (01-25-2021)
Old 01-25-2021, 08:54 AM
loukos
Thanks Kevin,
What turbines did you use?
Old 01-25-2021, 08:56 AM
loukos
Thanks Kevin,
Old 01-25-2021, 08:57 AM
patf
patf's Avatar
Matt
I was wondering as well... guess so
https://www.jettechusa.com/collections/exhaust-tube
Old 01-25-2021, 10:32 AM
kevinthoele
Originally Posted by loukos View Post
Thanks Kevin,
I flew them in AMT 180, Jetcat 120's and one other 100 class engines. I think they do best one big single engine 40lb plus class
Old 01-25-2021, 10:33 AM
kevinthoele
If I were to do another I would use 220 class engine
Old 01-25-2021, 11:04 AM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Originally Posted by patf View Post
Matt
Ill be damned! I thought Hiep Do was only one making bifurcated pipes. Is this link current pat?
Old 01-25-2021, 11:40 AM
JSF-TC
JSF-TC's Avatar
Yes, Gary does make Y-Pipes.
He worked with me to build my custom pipes for the Buccaneer and he was a pleasure to work with. Build quality of the pipes is excellent.
Paul
Old 01-25-2021, 08:21 PM
loukos
Agreed on the turbine size, my question is if the tamjets pipe with the quoted diameter is ideal for the 200 class turbines
Old 01-26-2021, 04:50 AM
patf
patf's Avatar
Buck
Just pulled it the other day.
Loukos, you may reach out to Hiep - he used to make the pipes for Tam - and see if what you have will take that size turbine. can someone post his contact email?
Old 01-26-2021, 04:56 AM
loukos
Buck
Hi Thanks, i actually got a respons from Tam himself, my thrust pipe is only for 28-34 lbs turbine
Old 01-27-2021, 05:41 AM
kevinthoele
Found some old notes that said the Olympus pipe was 3.57 inches at bellmouth and 2.9 inches at inner pipe at tail.
Hope this helps
Kevin
Old 01-27-2021, 07:55 AM
loukos
Hope this helps
Kevin
Thanks Kevin, much appreciated
Old 01-27-2021, 02:56 PM
kevinthoele
I'm sure those were somekind of metric round number
