XICOY new Telemetry Sensor - Telemetry X
Based on many request, Gaspar has upgraded the Xicoy Telemetry Sensor with a "Resettable" option. Now you can reset the fuel consumption back to 100% when you disconnect your wing tank. The procedure is very simple:
1. Maintain idle RPM for 2-3 Sec.
2. Then advance throttle fully quickly (less than 1sec) and back to idle - Like start procedure
3. Remain at idle for 2 sec.
Then your fuel consumption reporting is reset back to 100%
Video here
The sensor is now available from Xicoy Electronics or your local distributor.
David
Video here
David
T22 Warrior (02-19-2021)
I was discussing with Gaspar the other week about getting some of mine updated. I had some older Telemetry 2 & 3 sensors, but they don't have sufficient processing/ memory to take the current software.
Gaspar indicated that they were looking at a cut-down s/w (maybe single radio brand only) that would fit the older units.
Paul
Paul
That is how the VSpeak turbine telemetry sensors work. When you advance the throttle to 100% for the 2nd time it resets. This can be activated/deactivated depending on if you need the feature or not. This is available for any turbine and any radio system.
JanR
JanR
