"Flight Of The Intruder" Grumman 1:5.5 A6 Intruder Redesign & Build
#126
Would I be correct in assuming that is for making canopies and windshields? My bigger question is how do you make smaller, single parts? Is there some sort of cover that you put on the platen or carrier frame or what? I know I need to make some canopies and windshields for some of my boats but what I've been able to find are just too small for the sizes of my boats
#127
Vacuum Form Master Parts
Hydro,
With respect to our molding small parts...with twenty plus v-form part plugs there are no individual "small" parts. To pull smaller parts paritions can be plced onto the perforation table leaving proper forming area. we probably will not pull less than 24"x24".
Original 33+ year old vacuum formed parts from the John Mills "Flight Of The Intruder" film version of Stephan Coonts' novel.
Small (relative term) vacuum form part masters poured by Thomas White for MAC.
Canopy vacuum forming master plugs.
Master vacuum form parts are created in high temp resin poured into 33+ year old original movie model vacuum formed parts.
Original clear canopy parts.
New side canopy vacuum form masters beside of 33+ year old original "Flight Of The Intruder" side canopies
Below is the yet to be created windshield canopy frame and an animation of how the fuselage cutout master works.
Below is the only known portion of the canopy template (center overhead frame) around which seven canopy parts are arranged.
#128
My Feedback: (29)
First, thank you for your suggestion. I appreciate your enthusiasm and time to follow this thread. There are issues beyond well rounded Cheerios... Most important is weight bearing/shape retention of both tire and wheel axle hole.
There was a brand of wheel and tire manufactured by/for an unnamed company which would literally melt/misshapen from axle friction heat. My A4 succumb to these issues in what was a typical Texas afternoon sun. After three or four landings Scooter returned to the pit with more than its fair share of wobble considering it only weighed 10 pounds. Plastic, especially NOW, is not to be trusted to stand up to its seller's claims. I seek the Robart, or a known to be a real equivilent "tire" which properly fits the Robart 4.5" smooth center aluminum wheel. New or Used
#129
That is a lot of work, making all of the molds and forms. They do look really good, just waiting to see the final product The reason I asked is I need to be able to make 4.9" wide 1/8th scale F-16 canopies. My issue is that all of the vacuforming tables I've found either won't handle the length I need or are way to big.
#130
Thanks Gary!
I forgot about Tommy's wheels. Will call him tomorrow. Thanks for the heads up. There is a general shortage in the industry due to a single primary supplier. When I get my 4 1/2 hubs back I will order one of the Dubro tires. If you don't mind...can you identify the explicit 4 1/2 Dubro tire...they have a few. Its the donut hole that matters.
#134
Next...Rubba-Dub-Dub Its The Tub.
The printed cockpit parts arrive from Sam this morning. Tomorrow night (Saturday) its into the tub...and this too
#135
Cockpit Tub Layout
This requires flatening so everything within the tub will fit. There is literally little room for two humans in an A6. And they actually shoe horned two more in a 36 inch addition when designing the EA6B. I will return to post the CNC cut tile for the tub unwrapped perimeter.
#136
And while that is mostly true, they also went to a much smaller APS-130 search radar with no targeting system that took a lot less space. The nose radome ended up being only 24" deep, at most, instead of the big radome found on the Intruder. Truth be told, the Prowler actually had a lot of leg room. While sitting in the right front seat, I could not touch the forward bulkhead with my foot with my back fully against the chute pack. When you figure my legs were almost three feet long, that gives you an idea of how far the seat was from the bulkhead
#137
Through the evolution of A~EA in both 6 and 6B, this being 30+ years, I would guess when a functional device got smaller the space was rapidly appended by additional AEW.
I am curious if you ever utilized the RAT? I imagine with all the high wattage devices onboard the B things were lit up like a Christmas tree during "working hours".
#138
The "RAT" was an emergency use item. If the plane lost all electrical power, the "RAT" would be raised to keep the engines, radios and some of the navigation gear working. One engine generator could run the entire aircraft for a short time but, if one failed, several systems were shut down to protect the second.
This is, in many ways, the same as the "RAT" on commercial jets. The difference is the Prowler "RAT" provided emergency electrical power while the "RAT" on a commercial jet runs an complete emergency hydraulic system that operate only part of the flight control surfaces, just enough to keep the plane in the air until it cam make an emergency landing
#139
Its Saturday...Into The Tub I Go ;^)
11" x 12" x 6" small...but a perfect fit.
Purrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrfect
#141
Tooling Between The Lines _______________
Bam!!!! As Emeril yells ;^)
Its not as simple as paper dolls but can be an exceptionally accurate aid in scale designing. You mix artistic Vets with CAD skills and you get scale modeling tools. Where else would one find a complete cockpit layout/floorplan? You certainly are not going to find it in your typical documentation...even factory docs...they are not composite.
Years ago, I created a design toolbox (software) which evolved as OpSys have. This with multiple hardware tools permits creation and extraction (reverse engineering). These are rarely an out of the box and off the page solutions. I have found this better than plastic model parts as a resource.
This does require manipulation however it is faster than CAD edited parts scans with printed results which usually require additional editing before printing again for hours. If you've been following (reading between the lines) my threads you understand the process...;^)
#145
Looking for feedback...
The pilot's in a seat without parachute seat warmer. Pilot fits width but I'm concerned about head height when parachute is beneath him.
I have individual seat components printed by themselves...mo'better relative to reduction of rafting. Feel free to express your opinion.
#147
Wing Dings...
A BIG Thank You goes to Scott Adams who loaned us his fiberglass wing pylons from his DCM A6. They were missing in action on ours. Our movie 6 had balsa pylons damaged in the Kemah hurricane. We created molds to produce these in volume.
Next to mold are the weapons rails for each of the four pylons. We have releases for the retarded MK-81/82's. Though the 1:1 could carry/release 24 retarded iron I fear that would be a-wee-bit much for anything less than a kero 6. Anticipate releasing 4 Mk-81/82's.
#149
Tub looks good, so far. Gotta throw a correction at you however. The Intruder could handle up to 30 MK 81/82s on MERs or 15 MK 83s on TERs. Due to range issues, they normally carried:
- a centerline drop, as shown in the picture, reducing the load to four MERs with 24 Mk81/82s or four TERs with 12 MK 83s
- two drops on the inboard wing pylons, reducing the load to three MERs with 18 MK 81/82s or three TERs with 9 MK 83s
#150
Sam recovered enough from wrenching his back to put the cockpit tub template to work this afternoon. We discovered the damaged canopy area of the movie model was crudely "sawed off the fuselage"...leaving nothing of the original parting lines. Why would anything on this project be any other way??
.We have enough pics and measurements to properly create a scale canopy frame though everything is across the fuselage curve. The A6 canopy is similar to egg shape of an OV-10. We have new clear canopy parts from molds made using the 33 year old original "Flite Of The Intruder" movie parts.
