Upgrading servo connectors?
While I was out flying my T-one, before the second flight I did my normal ground check and noticed one of my elevators wasn't working (glad it didn't fail on the first flight) . After a little investigating it seemed like maybe the connector wasn't fully seated so I secured it with a connector lock. I did another preflight and everything seemed okay; but after taxiing out I did another quick check and the elevator had stopped working again.
I brought her in and did a more thorough check and it appears the connector itself is no longer reliable.
So I'm looking at upgrading connectors on both elevator servos, and maybe the rudder; but I'm wondering what, if any, upgraded connectors people are using in their jets to replace the stock servo connectors. I thought about Deans Micro-Plugs, but figure there might be something better. FWIW: I prefer to solder over crimp.
TIA
TIA
Those little yellow connectors are Amass MR30 (available almost everywhere, ebay, amazon, etc) and perfect for removable horiz and vert stabs.
If you don't want to solder yourself then you could buy pre-wired versions from Powerbox as mentioned above. Digitech also sells them in pre-made leads.
https://powerbox-americas.com/collec...remium-one4one
https://www.digitech-aerosports.nl/p...-servo-lead-jr
luge_racer (03-18-2021)
My 2c: For servo leads, I will take crimping over soldering any day. reason is that when you solder, the end of the solder creates a stress point, where cables can break to fatigue. Crimping is way more flexible and durable. It is tedious, but the result is a much more durable joint (again, just my pov)
My Feedback: (7)
If you guys like to crimp your connectors, it might be worth having a look at our Ultimate Servo Connectors, that come in 3, 6, 8, 10, 12, 16 and 20 pin plugs.
These are gold plated, certified for 5000 cycles of connection/ disconnection. Sustains 15A continuous @ 8V and 20A burst.
Best of all, the price-for-pin ratio is very good.
https://www.ultimate-jets.net/produc...ervo-connector
My Feedback: (53)
