The new BULL Mo1 !
jcterrettaz (12-08-2021)
The following 3 users liked this post by Canadian Man:
Roberto HA (12-31-2022)
#31
The Bull is complete!
Overall thought on the Aircraft and build.
- It's very quick! With all the hinging and control surface work already done it's a breeze.
- Hardest part and most time consuming was installing the landing gear. Mains needed to be built up a bit.
- All the included hardware is top notch!
- Pipe and turbine alignment was a breeze.
- Love the fact that the inside of the Fuselage is already finished and painted.
- Final weight of the aircraft is amazingly light. Lighter planes fly better and the BULL does just that. Massive surfaces on a 30lb plane will be tons of fun.
Thanks for watching the BULL Build.
The following 2 users liked this post by Canadian Man:
Daveeast (01-06-2023),
Roberto HA (01-04-2023)
#33
Batch #2
Pipe very easy to mount. Great access through bottom hatch. I added wood blocks under pipe to screw into. I also added some hatch support in the middle of the opening on the front and back.
Very easy engine mounting.
Carbon tail comes predone. 3 x 2mm screws and it's done.
#34
Batch #3
On it's legs for the first time
CMJets sent me a split tank at my request instead of the 4L option. I wanted the split tank so it would pull from the 3L Section first then use the 1L tank for final passes and landing. Using the Fuel telemetry we will know when 3L is burned and it's time to land.
