Reload this Page >
Fuel system questions
Old 05-30-2021, 01:27 AM
jerrybern
Default Fuel system questions
Hello, I have posted in the past about festo fittings, I have the fittings I need.They are 4 mm tubing, my question is How do I hook up tygon fuel tubing to these fittings?The gas start is a no brainer, however the liquid fuel is the problem, what size tygon do I use? The turbine is a older Jet Central Rhino
thanka, Till next Time
Jerry B
Old 05-30-2021, 01:58 AM
Dansy
My Feedback: (53)
Dansy's Avatar
Festo fitting…guessing your talking about the quick, tygon doesn’t work with those, use either barb or Festo line available in different sizes
paulhat (05-30-2021)
Old 05-30-2021, 03:55 AM
Len Todd
I use a barbed fitting to connect the festo type fuel line to the tygon fuel line. Then the festo type fuel line goes into a festo fitting. Depending on the size of your tygon fuel line, you may need an adapter (e.g. 6mm to 4mm). Tygon tubing will not work well when placed directly into a festo fitting.
Old 05-30-2021, 07:47 AM
jerrybern
Thank you ,
now what size tygon tubing do a I use,then I need 4 to 6 mm barbs?
Old 05-30-2021, 07:57 AM
Len Todd
If I recall correctly, use 3/16" tygon and it fits on a 6mm barbed fitting.
Smaller O.D. tygon may fit on a 4mm x 4mm barbed fitting.
Also, I wire tie all connections to barbed fittings.
Old 05-30-2021, 08:03 AM
jerrybern
I have been looking on a few sites since your reply, I am still somewhat confused, the ones on Aeropanda are metal and they plug into the festo fitting? and the tygon goes over the barb end. Do I understand this correctly?
thanks
Jerry B
Old 05-30-2021, 08:17 AM
Len Todd
Take a look at this fitting. Festo 6mm – 4mm connector – Dreamworks Model Products – #1 in Radio Controlled Jets and Accessories (dreamworksrc.com)
Old 05-30-2021, 10:58 AM
Dansy
My Feedback: (53)
Dansy's Avatar
thanks
Jerry B
Tygon into the 6mm side and Festo out of the 4mm side…
https://www.aeropanda.com/collection...tor-8mm-to-6mm
Old 05-30-2021, 11:00 AM
Dansy
My Feedback: (53)
Dansy's Avatar
thanks
Jerry B
https://www.aeropanda.com/collections/festo/products/festo-barbed-tubing-connector-4mm-to-3mm (It’s actually 6 to 4mm)
Old 05-30-2021, 11:20 AM
jerrybern
does the metal barb go directly into the festo or do you use tubing in the festo?
thanks
Jerry B
Old 05-30-2021, 11:23 AM
Dansy
My Feedback: (53)
Dansy's Avatar
thanks
Jerry B
‘Directly into the Festo (either 4 or 6mm) they basically replace the quick one…..or into tygon….
Old 05-30-2021, 12:21 PM
causeitflies
causeitflies's Avatar
thanks
Jerry B
FESTO is the name of the company that makes the two types of fittings. One fitting is the quick connect type and the other is the double barb type. The quick connect type uses the "festo" type of fuel line and the barbed type can use that and/or Tygon. The double barbed fittings suggested above can be used to connect the two types of fuel line.
Old 05-30-2021, 12:28 PM
jerrybern
iI guess I'm not understanding it, on my fuel solenoid there is a 4mm festo fitting ,. I understand that tje barb is reducing the diameter of the tygon. Do you use a piece of tubing in the festo and that connects to the barb or does the barb plug into the fitting directly? Sorry about all of the questions.
Old 05-30-2021, 12:31 PM
causeitflies
The barb does not go into the quick connect. Only tubing goes on the barb and only hard tubing goes into the quick connect. So yes, a piece of tubing goes into the quick fitting and then to the barb.
Old 05-30-2021, 01:32 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Rather than wire ties on Turbine fuel systems, might I suggest that double wrapped Safety wire might be a better option?
Old 05-30-2021, 01:40 PM
Dave Wilshere
What turbine? To and from the valve would normally be 4mm od (2.5mm I’d) Clear SMC tube rather than Festo. This presumes the pump has 4mm out and turbine 4mm in.
Old 05-30-2021, 01:53 PM
Desertlakesflying
My Feedback: (28)
No wire ties, and no Tygon unless you want headaches and problems, and possibly a ruined airplane/equipment.
Festo fuel line and safety wire in place of wire ties.
Old 05-30-2021, 02:32 PM
jerrybern
I have a older Jet Central Rhino, gas start
Old 05-30-2021, 09:03 PM
Dave Wilshere
OK, so what is the plumbing order for you to need the step down around the valve?
Old 05-30-2021, 09:31 PM
jerrybern
Here is what ai have
Here is what I have Thanks Jerry B
Old 05-30-2021, 10:35 PM
Dave Wilshere
Using a hopper tank? You just need to step between the last tank and fuel pump. Everything else is 4mm SMC tube
Dave
Old 05-31-2021, 04:45 AM
jerrybern
Dave
Thanks, David
I ordered a VAT from Chief Aircraft,Now What is SMC tubing? Please forgive all of my questions, this is my first Turbine and there are not my turbine flyers at our local field.
I plan on going to a few jet events this summer just to see there set ups
Old 05-31-2021, 05:21 AM
paulhat
SMC is just another brand. They sell similar products to festo but seem to be a bit cheaper (well here in Australia anyway).
Old 05-31-2021, 06:49 AM
Dave Wilshere
Yes, different brand, harder tube, usually clear.
Old 06-01-2021, 04:48 AM
olnico
olnico's Avatar
We sell specialized fuel tubing for the UAV industry:
https://www.ultimate-jets.net/collec...ct-fuel-tubing
This is directly compatible with with push-to-connect Pisco fittings:
https://www.ultimate-jets.net/collections/fuel-hardware
Even on the suction side of the pump. This makes plumbing a lot easier.
Check this article out:
https://www.ultimate-jets.net/blogs/...nnect-fittings
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
