Mirce Models F-104 Build
Hi everyone. I will be doing a build thread for the new project that I will be starting soon together with my father. It's a Mirce Models F-104 1/4 scale. I know that there is another build thread but I didn't want to hijack that thread. I will be trying to go scale as much as possible with this build, also as integrating some modifications I have seen on other threads or that we will come along with.
Until now we have only received the 3D printed wing tip tanks as the kit is being held by customs. I am currently building a Carf Tucano so this build will commence after the Tucano, hence, there will be a slow start to the build.
Planning to put a Kingtech 260 and using the attached JASDF special scheme.
Any heads up would be appriciated.
The following 5 users liked this post by johannmicallef:
drfred58809 (01-20-2022),
grbaker (01-20-2022),
Martinik1 (01-07-2022),
SAP_2000 (01-21-2022),
u2fast (01-07-2022)
The kit was cleared but customs last week. I did open the brown box to check that nothing is damaged and yes, all looks good.
I am currently building a CARF Tucano so as soon as I am done with that one, I will start the F-104. Hopefully within a months’ time. I started searching for balsa sheet's, at the moment it's a nightmare to find balsa sheets at all here in Europe, let alone at good price.
Here's a list of some of modifications I am planning to implement of this kit;
While some of the above are an easy fix, other's will be a headache, but I'd like to make the F-104J as close as possible to a scale replica. Will be interesting.
- Install navigation/formation/landing lights - 14 in total on the F-104J
- Fix intake shape, they need to be round, not with a flat side (easy fix)
- Fix Aft. upper fuselage, just between the spine and the vertical stabilizer (the kit has the spine going straight into the vertical stab while the real F-104 did not)
- Add leading egde slats and make the leading-edge sharper
- Add a parachute hatch and the parachute itself
- Fix nose cone shape, make it more conical like the real F-104
- Try and add air brakes. This depends on the formers position and the way the aft part of the fuselage is split as from my calculation; the air cylinder would be in the middle of the two sections
- Modify the vertical stab to have the elevator servos hidden inside.
Martinik1 (01-25-2022)
My Feedback: (8)
Just ordered my F-104 kit and I can't wait to get started on it. When my kit arrives it will be best day ever. As of right now, I plan on covering it and trying to keep it as light as possible. With that in mind does anyone know if it is sheeted in 3/32 inch balsa sheet or 1/8 inch balsa sheet. Just trying to source sheeting as I notice it has gone up in price quite a bit. And many thanks to Martin at Mirce Models for all of his help as it is much appreciated.
Alex
Alex
Viper1GJ (02-23-2022)
Alex
Alex
My Feedback: (8)
Just applied my first coat of filler on the rear fuselage section. Will fit up servos once my servo plates arrive. Cut the sheeting flush with the rear former as I plan on adding some thin aluminum back there in case of a hot start.
Hope johannmicallef does not mind me posting in his forum every once in awhile as I fully understand that he is going for competition scale. Even though I have built many airplanes am still perfectly happy with stand way off scale. Plan on building this giant F-104 to fly by keeping it as light as possible. Than again my plans often change...........
Alex
Alex
The following 2 users liked this post by xradarusa:
BadBill (04-14-2022),
jcterrettaz (04-13-2022)
Time to give an update on the build of the F-104. After a couple of busy months, two weeks ago we managed to start the build. Until now, the kit goes together very nicely. I found a few missing components from the kit which Mirce has already shipped out the replacment, excellent service from his side.
As you can see, everything in packed in packs and marked for their according location.
Started from the nose cone.
Started sheeting the fwd section with 3mm balsa
Nose section ready
Before we started sheeting the nose cone, we added a few pieces of balsa to make the nose cone more cone shaped as the kit had the top part flat which is not scale.
Nose section ready
