ds 24 JETI dual path & Swinwin Turbine programing
I am pulling my hair out trying to get a new Swinwin 140B turbine programed to a ds-24 Jeti running in dual path.
Has anyone had any success doing this?? I would appreciate any help on this!
Dick Mundee
Dick Mundee
LA jetguy (03-07-2022)
My Feedback: (7)
Setting it to 10ms should be fine as that is the transmit rate of the transmitter. Auto only updates PWM outputs every time a frame is successfully received which SHOULD in theory be 10ms, however there are a surprising number of individual frames dropped, even with nearly perfect signal quality. This can cause a slightly jittery output when Auto is selected. Setting it to 10ms (or even 5ms) will eliminate this slight jitter which I suspect is what would be bothering the turbine ECU rather than the actual frequency. Be aware that the output period also changes the refresh rates for all your servos as well so setting it slower than needed can reduce the rate your servos are updated at. Of course setting output period to 10ms or faster requires that all servos connected to the receiver be able to accept a frame rate of 100Hz or greater. Many analog servos can't support that so if you have any servos connected to the receiver then output period should be set to the default output period of 17ms or even 20ms.
