Jet Legend L-39 canopy
Its disappointing Jet Legend cant make one for you at a cost.
What's different about the BVM canopy as I was under the impression its the same jet?
are final-modellbau able to help at all?
If it's stopping you flying your jet just do what I did.
Patch it up with some epoxy & glass mat, fill it, sand it & paint it white or silver.
Painting it black may lead to it deforming in the hot sun.
Replace it when one becomes available.
It's a V1 version which is not made anymore and the V2/PNP is split canopy. However the 'glass' part is the same (which I stock). I didn't get an answer when I tried but as with other older products in their range, they probably no longer have a viable mould for it.
The V2 has been around for a number of years so that could be expected.
Jeff
wwww.zedjet.com
Jeff
wwww.zedjet.com
