Reload this Page >
JP Gear with Xicoy LG15
Old 05-04-2022, 01:21 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Default JP Gear with Xicoy LG15
I have a new Global Aerojet F15 inbound. I haven't had much luck with the JP controllers with gear doors or brakes. I want to use an Xicoy LG15 controller. What amp settings have you guys been using to prevent smoking the gear motors? Thanks
Old 05-04-2022, 03:16 PM
Bob_B
Bob_B's Avatar
Tom I installed the LGC 13 in my hot with JP gear and it works fine on the default values.
Old 05-05-2022, 03:46 AM
Dansy
My Feedback: (53)
Dansy's Avatar
When I installed those controller in my JP gear jets….I just asked Shane Yang on FB and while he said he didn’t recommend switching (y’a right) he told me the reading….it will I proved the break a little
Old 05-05-2022, 04:35 AM
Bob_B
Bob_B's Avatar
Care to share your values?
Old 05-05-2022, 04:37 AM
Dansy
My Feedback: (53)
Dansy's Avatar
I will look to see if I still have them….the value I had were for the T-1, mini t-1….
I can only find this one…it was for my t-1 his answer….
The retract of our ER-150 start max current is about 1.2A. the working current is about 0.8A.
Old 05-05-2022, 04:49 AM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Thanks guys. Gary Jones gave me his settings and with these I may be able to keep the smoke in. I think the T1 gear will be similar size and settings.
Old 05-05-2022, 05:32 AM
Agrav8ed
Thanks guys. Gary Jones fave me his settings and with these I may be able to keep the smoke in. I think the T1 gear will be similar size and settings.
Would you mind posting the settings.
Tone
Old 05-05-2022, 07:48 AM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Mains 1.4 A, nose .8A. 13 sec retraction on mains, 9 sec on nose.
Old 05-05-2022, 10:48 AM
Agrav8ed
Thank you, Thank you,
Tone
Old 05-05-2022, 11:31 AM
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Here is what I sent Tom from my testing with amp meter on the F-16 XL gear.
I set these values into the LGC-15 and they seemed to work OK. The problem I had was the brakes needed more voltage to stop the jet and as I recall the LGC-15 was limited to 2S LiPo. So I switched to a different brake controller.
Gear times and amps for JP F-16XL gear.
JP (Shaun) says 1.8 amps for the F-16 gear from an FB response.
Here's the max values I saw when I tested the gear
RMG 13 sec 1.4 amps
LMG 13 sec 1.4 amps
NG 9 sec .8 amps
I just used TLAR to set the unload time, I don't remember what value I used but it just unloaded the jack screws a little.
Gary
Old 05-05-2022, 12:00 PM
Agrav8ed
RMG 13 sec 1.4 amps
LMG 13 sec 1.4 amps
NG 9 sec .8 amps
Gary
The LGC can use up to 3s for gears and brakes. However, it shares a power connection so you cannot run 2s to the gear and 3s to the brakes.
Tone
Old 05-05-2022, 12:28 PM
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Originally Posted by Agrav8ed View Post
The LGC can use up to 3s for gears and brakes. However, it shares a power connection so you cannot run 2s to the gear and 3s to the brakes. Tone
I think my JP gear controller was limited to 2S printed on the case. That's why I was using 2S for brakes at first.
Can the JP gear motors run on 3S LiPo?
Gart
Old 05-05-2022, 01:00 PM
Dansy
My Feedback: (53)
Dansy's Avatar
Gart
‘Not if you want to keep the smoke in
2s Only……
Old 05-05-2022, 01:59 PM
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Originally Posted by Dansy View Post
‘Not if you want to keep the smoke in 2s Only……
Yea, that's what I thought. Glad I kept the blue smoke in!
G
Old 05-08-2022, 03:40 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
Coming soon to a hangar near me.
The following 3 users liked this post by tp777fo:
mongo (05-08-2022), Viper1GJ (05-08-2022), wildnloose (05-09-2022)
Old 05-08-2022, 05:05 PM
mongo
My Feedback: (15)
mongo's Avatar
looks good tom.
tp777fo (05-10-2022)
Old 08-04-2022, 09:34 AM
In the Haze
In the Haze's Avatar
How do you slow down the servos on the gear doors. Is it possible on the LGC13C.?
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
